Logitech C920S Pro HD Webcam
Quicklinx: G5VQWS00 Mfr#: 960-001252
Compatibility: PC, Mac
Interface: USB
45 In Stock
£71.89 ex VAT
£86.26 inc VAT
Polished, professional Full HD video calls. The C920S Pro HD Webcam delivers remarkably crisp, clear and detailed images in vibrant colors. HD autofocus and light correction adjust to the conditions to provide consistently high definition, and the dual mics on either side of the glass lens capture the natural sound of your voice.
  • GREAT VIDEO CALLS. PRIVACY INCLUDED
    Make a strong impression in your video conference calls with a diagonal, fixed 78° field of view to perfectly frame you and your space-plus full HD at 1080p/30fps or 720p/30fps. The five-element glass lens captures razor-sharp images and clear colors, while autofocus adjusts smoothly and precisely for consistent definition and fluid video. Flip the privacy shutter closed when you want to be off-camera
  • ALL-IN-ONE CONTENT CREATION WITH CAPTURE
    Easily create, record, and customize settings with our Capture app. A suite of features lets you fully edit and customize your stream, so you can add transitions and text overlays, customize webcam settings, and more
  • HD GLASS LENS WITH PRIVACY COVER
    The full HD five-element glass lens and premium autofocus capture razor-sharp, clear images, adjusting smoothly and precisely to provide consistent high definition in conference calls. A convenient privacy cover protects the lens-and your privacy
Logitech HD Pro Webcam C920S - webcam
Webcam
Audio
Yes: built-in stereo microphone
9.4 cm x 2.4 cm x 2.9 cm
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Focus Adjustment
Automatic
USB
USB cable - 1.5 m
Webcam
Audio Support
Wired
9.4 cm
2.4 cm
2.9 cm
Camera
Max Digital Video Resolution
1920 x 1080
Digital Video Capture Resolution
720p, 1080p
Frame Rate (max)
Lens Construction
Focus Adjustment
Automatic
Horizontal Field of View (degree)
78
Computer Interface
USB
Privacy shutter, clip mount
USB cable - 1.5 m
Compatibility: PC
Compatibility: Mac
Interface: USB
Brand: Logitech
