Logitech C920e HD 1080p Webcam
Quicklinx: G88YWS00 Mfr#: 960-001360
Compatibility: Mac, PC
Interface: USB
48 In Stock
£76.00 ex VAT
£91.20 inc VAT
C920e is a work-from-anywhere webcam that delivers HD video meetings that look and sound better than most laptop built-ins.
The 78° diagonal field of view displays individual users in a well-balanced visual frame while two integrated omnidirectional mics capture audio clearly from up to one meter away.
Built-in HD autofocus ensures you're seen clearly when on camera, while a detachable privacy screen flips up and down to cover or expose the lens.
C920e is designed with a sturdy, adjustable clip that makes it easy to mount on any laptop or external monitor. Plus it has a 1/4" thread to enable mounting to a tripod.
C920e works with all popular video calling applications, including Microsoft Teams, Skype for Business, Google Voice and Meet, Zoom and others to ensure compatibility and seamless integration in the workplace.
  • Ideal FOV for Individual Users
    With a 78° field of view (FOV), count on the C920e webcam to display individual users in a well-balanced frame. The fixed FOV captures a comfortable view of the user and their environment while also providing sufficient room to visually share projects and other items of interest
  • Rich Natural Sound
    The C920e webcam features two integrated omnidirectional microphones that capture your audio clearly from up to one meter away so your voice always sounds natural and clear
  • Keep Sharp, Automatically
    Built-in HD autofocus ensures you're seen clearly throughout your video calls. Working in tandem with automatic light correction, C920e delivers optics that help you look great in all your video meetings
  • Privacy at Your Fingertips
    The C920e webcam features a detachable privacy screen that flips up and down to cover or expose the lens. A simple glance at the physical cover confirms for sure if the lens is able to see into your space or not
  • Business Ready by Design
    The C920e webcam works with all popular video calling applications, including Microsoft Teams, Skype for Business, Google Voice and Meet, Zoom , Cisco Jabber , BlueJeans, and GoToMeeting to ensure compatibility and seamless integration in the workplace
  • Versatile Mounting Options
    Mount the webcam wherever it works best: screen, notebook, or tabletop. C920e is designed with a sturdy, adjustable clip that makes it easy to mount on any laptop or external monitor. Integrated tripod threads provide extra versatility to mount the webcam on a tabletop or full-size tripod as well
Logitech C920e - webcam
Webcam
Audio
Yes: built-in dual omni-directional microphones
9.4 cm x 2.4 cm x 2.9 cm
Wired
Camera
Frame Rate (max)
30 frames per second
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
1 - USB cable - integrated - 1.5 m
RightLight 2 technology, Skype for Business compatible, Microsoft Teams compatible, Zoom compatible, Google Voice compatible, Meet compatible
Webcam
Audio Support
Wired
9.4 cm
2.4 cm
2.9 cm
Camera
Video Modes
720p, 1080p
Digital Video Capture Resolution
720p, 1080p
Frame Rate (max)
Still Image Capture Resolution
1080p
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
78
Computer Interface
USB 2.0
Privacy shutter, clip mount
1 x USB cable - integrated - 1.5 m
Google Chrome OS, Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
Compatibility: Mac
Compatibility: PC
Interface: USB
Brand: Logitech
