Logitech C920-C Webcam
Quicklinx: 9TTJWS00 Mfr#: 960-000945
The Logitech C920-C Webcam is the professional webcam that delivers true-to-life HD 1080p quality video. With a 78-degree field of view, UVC H.264 encoding and omnidirectional mics, the C920-C brings high-quality desktop face-to-face collaboration to UC.
  • HD 1080p 1 video at up to 30 frames per second
    Make a vivid impression with true-to-life, high definition video calls
  • UVC H.264 encoding technology
    Frees up system bandwidth by putting video processing within the camera
  • 78-degree field of view with true widescreen
    See more without having to reposition the camera or crop and zoom
  • Logitech RightLight 2 technology and autofocus
    Webcam intelligently adjusts to improve visual quality in low light and backlit situations at multiple distances
  • Omni-directional dual stereo microphones
    Designed to capture sound for clear communication in larger spaces like offices and small conference rooms
  • Convenient privacy shutter
    Easy lens closure for added privacy and security
  • Multiple mounting options
    Freedom to mount the camera wherever it works best – LCD screen, notebook, or tabletop – by using the attached clip or the tripod embedded thread
  • USB plug-and-play set up
    Easy to set up and easy to use
  • Designed exclusively for the Cisco Jabber experience
    Don't worry about setup or interoperability, this is the only keyboard/webcam/mouse combo exclusively selected and certified by Cisco for seamless integration with Cisco VXC, Jabber and WebEx Meeting Center solutions
Logitech Webcam C920-C - webcam
Webcam
Audio
Yes: built-in dual stereo microphones
12.6 cm x 4.5 cm x 7.3 cm
170 g
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
Focus Adjustment
Automatic
USB 2.0
1 - USB cable
USB 2.0 compatibility, RightLight 2 technology, Privacy mode, auto low-light correction, USB 3.0 compatibility, 1080p Full HD movie recording
3-year warranty
Webcam
Audio Support
Wired
12.6 cm
4.5 cm
7.3 cm
170 g
Camera
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Focus Adjustment
Automatic
Horizontal Field of View (degree)
78
Computer Interface
USB 2.0
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable
UL, FCC, RoHS, WEEE, TUV T
Microsoft Windows 7, SuSE Linux 11, Apple MacOS X 10.6 or later
Limited warranty - 3 years
