Logitech C120 Webcam
Webcam C120
Quicklinx: 7CRKWS00 Mfr#: 960-000540
Logitech Webcam C120 provides you the simple way to get started with video calling.
Logitech Vid is free, fast, and easy for you and anyone you call. It sets up when you set up the webcam. Your loved ones will see you in lifelike color when you talk to them, or you can take photos to share later.
The universal clip lets you attach the webcam securely to your LCD monitor or notebook, or sit it on a desk.
  • Includes Logitech Vid
    Now video calling is free, fast, and easy for you and anyone you want to talk to. It's built into your webcam setup, so you can call right away. Find out more about Logitech Vid.
  • Clear video calls
    A VGA sensor means the people you care about to see you in lifelike color. Megapixels? Sensor? Why is image quality so important?
  • 1.3-megapixel photos
    It's easy to take snapshots at up to 1.3 megapixels.
  • Universal clip
    You can attach your webcam securely to LCD monitors and ultra-thin notebooks, or sit it on a shelf or desk.
Logitech Webcam C120 - webcam
Webcam
Wired
Camera
Max Resolution
640 x 480
Optical Sensor Type
0.3 MP
Focus Adjustment
Manual
USB
1 - USB cable - 1.8 m
USB 2.0 compatibility
Webcam
Wired
Western Europe
Camera
Max Digital Video Resolution
640 x 480
Video Capture
640 x 480 @ 30 fps
Image Sensor
0.3 MP
Lens Construction
Focus Adjustment
Manual
Computer Interface
USB
Interfaces Details
1 x USB - 4 pin USB Type A
1 x USB cable - 1.8 m
Software Included
Drivers & Utilities, Logitech Vid
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista
Additional Requirements
Sound card, CD-ROM, speakers, USB port, Internet connection
System Requirements Details
Windows XP SP2 or later - 1 GHz - RAM 256 MB - HD 200 MB , Windows 7/Vista - 1 GHz - RAM 512 MB - HD 200 MB
