Logitech BRIO 4K UHD Webcam
Quicklinx: CQ85WS00 Mfr#: 960-001106
Compatibility: PC
Interface: USB
£191.60 ex VAT
£229.92 inc VAT
Step up to the world's most technologically advanced webcam and get professional-quality video for conference calls, streaming, or video recording. Our first 4K ultra high-def camera offers 5x digital zoom and RightLight 3 with HDR. Background replacement gives you the freedom to meet anywhere.
  • CAPTURE EVERY DETAIL IN 4K HD
    Stream crystal-clear video with superb resolution, frame rate, color, and detail. Logitech BRIO delivers 4K Ultra HD at 30 fps or 1080p at either 30 or an ultra-smooth 60 fps for outstanding clarity, smoothness, and detail. Get a closer look with 5x zoom
  • LOOK GREAT IN ANY LIGHT
    Now you can use your video conferencing, streaming, and video recording applications in any lighting condition - and always look your best. Whether in low light or bright sunshine, Logitech BRIO with RightLight 3 and high dynamic range (HDR) technology adjusts to highlight the most important subject: you
  • SECURITY MEETS CONVENIENCE
    Powered by both optical and infrared sensors, BRIO delivers fast and secure facial recognition for Windows Hello. No need to type a password for Windows 10: simply look into BRIO's lens to login
  • ADJUSTABLE FIELD OF VIEW
    Choose from three field of view settings to perfectly frame your video. For an ideal head and shoulders shot, pick 65 degrees. For larger groups or to capture more of the room, choose 78 or 90 degrees
  • 4K RECORDING
    Use BRIO with software like Camera for Windows 10, XSplit Broadcaster, OBS, and SwiftCapture to record in resolutions up to 4K
  • SMOOTH STREAMING
    BRIO retains a high frame rate whatever the lighting to match your gaming broadcast with no lag. Stream in full 1080p HD at up to 60 frames per second for smooth, fluid video that keeps up with your every move
  • CERTIFIED FOR BUSINESS
    BRIO is certified compatible with Skype for Business, Windows Hello, and Cisco Jabber , works with Microsoft Cortana , and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom. If your preferred application can recognize a webcam, you can use it with BRIO
  • MOUNTING & PRIVACY OPTIONS
    Mount the camera wherever it works best – LCD screen, notebook, or tabletop – with the adjustable clip, or mount BRIO on your own tripod instead. A removable shade flips down to assure privacy and peace of mind
  • 5X HD ZOOM
    Zoom in and pan around to crop out distracting backgrounds, perfectly frame you and a friend, or capture the entire scene. BRIO's next-generation 4K image sensor delivers HD quality without jaggies or blur, even when zoomed in
  • CAMERA SETTINGS
    Customize your BRIO and access pan, zoom, and image controls with Logitech Camera Settings software for Windows and Mac
Logitech BRIO 4K Ultra HD webcam - webcam
Webcam
Audio
Yes: built-in dual stereo microphones
Camera Mount Type
Tripod mount
10.2 cm x 2.7 cm x 2.7 cm
63 g
Wired
Camera
Max Resolution
4096 x 2160
Frame Rate (max)
30 frames per second
Video Modes
720p, 1080p, 4K
Focus Adjustment
Automatic
USB
1 - USB cable - 1.5 m
Passive infrared sensor, High Dynamic Range (HDR), 4K ULTRA HD engine, RightLight 3 technology, Infrared Facial Recognition
3-year warranty
Works With Chromebook
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
10.2 cm
2.7 cm
2.7 cm
63 g
Camera
Max Digital Video Resolution
4096 x 2160
Video Modes
720p, 1080p, 4K
Digital Zoom
5
Video Capture
4096 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps , 1280 x 720 @ 90 fps
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB
Removable clip, privacy shutter, carrying pouch
1 x USB cable - 1.5 m
Plug and Play
Apple MacOS X 10.10, Microsoft Windows 7 / 8.1 / 10, Google Chrome OS 29
Limited warranty - 3 years
Compatibility: PC
Interface: USB
Brand: Logitech
