Logitech Brio 4K Stream Edition - EMEA
Quicklinx: FM94WS00 Mfr#: 960-001194
10 In Stock
£188.09 ex VAT
£225.70 inc VAT
Capture the smallest details of your facial expressions and maintain full HD quality even as you zoom in. HDR shows you in more vivid and accurate colors, even in dim lighting. It provides 4 times the resolution of a full HD video and adjusts to changes in brightness, so your won't look dark when backlit or moving from outside to inside.
Stream 1080p/60fps video that's fluid, lifelike and hyper-fast. You'll also make a powerful impact by creating dramatic and unusual slow-mo replays thanks to the hyper-fast frame rate.
  • ULTRA HD 4K
  • HYPER-FAST FRAME RATE IN HD
  • OPTIMIZED FOR STREAMING
    All set for streaming, BRIO STREAM retains a high frame rate whatever the lighting to match your gaming broadcast with no lag. Its video calling credentials are impressive too, with razor-sharp images, smooth motion and natural colors
  • WIDE, ADJUSTABLE FIELD OF VIEW
    Adjust the field of view from a broad 90° to include more background to a narrow 65 or 78° that keeps the focus on you. Convey a crisp, professional image even in a cluttered setting by neutralizing the background. Choose from three AI background modes: blur, remove and replace
  • 12-MONTH PREMIUM XSPLIT LICENSE
    Logitech worked closely with XSplit to provide you with an all-in-one live streaming solution that delivers 4K compatibility and a high frame rate
  • INSTANT LOGIN WITH WINDOWS HELLO
    Sign in easily and securely to your computer with Windows Hello facial recognition log in - it's one less password to remember
  • ALL-IN-ONE CONTENT CREATION WITH CAPTURE
    With Logitech Capture, you can start recording high-quality video content the second you plug in your new webcam. It enables you to customize recordings, adjust your camera settings, and even create vertical video all with one intuitive interface
Logitech BRIO STREAM - live streaming camera
Live streaming camera
Audio
Wired
Camera
Max Resolution
4096 x 2160
Frame Rate (max)
30 frames per second
Video Modes
1080p, 4K
Focus Adjustment
Automatic
USB
High Dynamic Range (HDR), 4K ULTRA HD engine
1-year warranty
Works With Chromebook
Audio Support
Wired
Camera
Max Digital Video Resolution
4096 x 2160
Video Modes
1080p, 4K
Video Capture
4096 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB
Carrying case, removable clip, privacy shutter
Windows 8, Apple macOS Sierra 10.12 or later, Windows 10 or later
System Requirements Details
Core i5
Limited warranty - 1 year
Type: Video Conference Kit
Brand: Logitech
