Capture the smallest details of your facial expressions and maintain full HD quality even as you zoom in. HDR shows you in more vivid and accurate colors, even in dim lighting. It provides 4 times the resolution of a full HD video and adjusts to changes in brightness, so your won't look dark when backlit or moving from outside to inside.
Stream 1080p/60fps video that's fluid, lifelike and hyper-fast. You'll also make a powerful impact by creating dramatic and unusual slow-mo replays thanks to the hyper-fast frame rate.
                ULTRA HD 4KCapture the smallest details of your facial expressions and maintain full HD quality even as you zoom in. HDR shows you in more vivid and accurate colors, even in dim lighting. It provides 4 times the resolution of a full HD video and adjusts to changes in brightness, so your won't look dark when backlit or moving from outside to inside
                HYPER-FAST FRAME RATE IN HDStream 1080p/60fps video that's fluid, lifelike and hyper-fast. You'll also make a powerful impact by creating dramatic and unusual slow-mo replays thanks to the hyper-fast frame rate
                OPTIMIZED FOR STREAMINGAll set for streaming, BRIO STREAM retains a high frame rate whatever the lighting to match your gaming broadcast with no lag. Its video calling credentials are impressive too, with razor-sharp images, smooth motion and natural colors
                WIDE, ADJUSTABLE FIELD OF VIEWAdjust the field of view from a broad 90° to include more background to a narrow 65 or 78° that keeps the focus on you. Convey a crisp, professional image even in a cluttered setting by neutralizing the background. Choose from three AI background modes: blur, remove and replace
                12-MONTH PREMIUM XSPLIT LICENSELogitech worked closely with XSplit to provide you with an all-in-one live streaming solution that delivers 4K compatibility and a high frame rate
                INSTANT LOGIN WITH WINDOWS HELLOSign in easily and securely to your computer with Windows Hello facial recognition log in - it's one less password to remember
                ALL-IN-ONE CONTENT CREATION WITH CAPTUREWith Logitech Capture, you can start recording high-quality video content the second you plug in your new webcam. It enables you to customize recordings, adjust your camera settings, and even create vertical video all with one intuitive interface
- Logitech BRIO STREAM - live streaming camera
- Live streaming camera
- Audio
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 4096 x 2160
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 1080p, 4K
- Focus Adjustment
- Automatic
- USB
- High Dynamic Range (HDR), 4K ULTRA HD engine
- 1-year warranty
- Works With Chromebook
- Audio Support
- Wired
Camera
- Max Digital Video Resolution
- 4096 x 2160
- Video Modes
- 1080p, 4K
- Video Capture
- 4096 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps
Lens Construction
- Focus Adjustment
- Automatic
- Computer Interface
- USB
- Included Accessories
- Carrying case, removable clip, privacy shutter
- OS Required
- Windows 8, Apple macOS Sierra 10.12 or later, Windows 10 or later
- System Requirements Details
- Core i5
- Limited warranty - 1 year
