Logitech Brio 4K - Graphite
Quicklinx: J69BWS00 Mfr#: 960-001718
10 In Stock
£144.62 ex VAT
£173.54 inc VAT
The Logitech BRIO 4K is a live streaming camera designed for video quality. With a maximum resolution of 3840 x 2160, it captures videos in detail, making it suitable for streaming, conferencing, or content creation. The camera features automatic focus adjustment and offers three field of view settings for versatile framing options during calls or recordings. It incorporates RightLight 3 technology for optimized lighting conditions, ensuring high video quality in challenging environments.
Featuring digital zoom capabilities and a maximum frame rate of 90 fps, the Logitech BRIO delivers smooth streaming experiences. The sound is supported by built-in dual omnidirectional microphones with noise reduction, ensuring clear audio. Certified for use with Zoom and Google Meet, this camera is a reliable tool for work and entertainment. Connectivity is streamlined with a 1.5 m USB-A to USB-C cable, ensuring compatibility with modern devices.
  • HIGH QUALITY VIDEO CALLS
    Enhance your desktop video meetings to first-class quality with Brio 4K. RightLight 3 and HDR adjust to present you at your best in any lighting, from low light to bright sunlight. Record smoothly at up to 90 fps. Dual mics with noise reduction capture clear sound up to one meter away
  • PROFESSIONAL QUALITY VIDEO CALLS IN 4K HD
    Elevate your video collaboration with the Brio 4K webcam, crafted for professional performance. Capture every detail with stunning resolution and color. Enjoy ultra-smooth asynchronous sharing and recording at up to 90fps for fluid streaming
  • A PROFESSIONAL IMAGE IN ANY LIGHT
    Meet, stream, and record with Brio 4K in any lighting and always look professional on video. RightLight 3 with HDR automatically adjusts for low light, direct sunlight, or high contrast, ensuring you're always the focus
  • EXCEPTIONAL AUDIO EVERYWHERE
    Conversations sound natural and clear with Brio 4K. Dual omnidirectional mics capture sounds up to 3 feet away, while active noise cancellation keeps you focused, suppressing distracting background noise for seamless collaboration
  • A PERFECT FRAMING
    Select from three diagonal field of view settings to frame your video perfectly. Use Logi Options+ presets for an ideal head-and-shoulders view (65° diagonal) or to showcase more surroundings (78° or 90° diagonal). Requires Logi Options+ app. Logi Options+ only available on Windows and macOS. Download or view software compatibility at logi.com/optionsplus
  • FOCUS ON YOU
    The 65° diagonal preset is ideal for optimal eye contact and face-to-face conversations where you want the focus on you, not so much the workspace around you
  • BALANCED FRAME
    The 78° diagonal preset reveals more of your setting, providing a fuller glimpse into your physical environment while also maintaining good eye contact
  • FULL CONTEXT
    The 90° wide-angle preset displays even more of your environment and is ideal for showing physical objects and whiteboard content on camera
  • ULTRA-SMOOTH RECORDING
    Brio 4K maintains up to 90 fps in any lighting for high-quality recording, asynchronous presentation sharing, and fluid broadcasts that follow your every move. High frame rates are perfect for slow motion or extra-smooth, fluid video streaming
  • SECURITY MEETS CONVENIENCE
    Sign in securely and easily to your computer with Windows Hello facial recognition-it's one less password to type or remember. Simply look into the Brio 4K lens and you're in
  • FUEL YOUR CREATIVITY
    Whether you're meeting virtually, streaming live, or recording, Brio 4K optimizes your video experience. With Logi Options+ , personalize your appearance using custom filters, dFOV, and more, ensuring you always look your best for your audience. Requires Logi Options+ app. Logi Options+ only available on Windows and macOS. Download or view software compatibility at logi.com/optionsplus
Logitech BRIO 4K - live streaming camera
Live streaming camera
Audio
Yes: built-in dual omni-directional microphones
10.2 cm x 2.7 cm x 2.7 cm
63 g
Graphite
Wired
Camera
Max Resolution
3840 x 2160
Frame Rate (max)
90 frames per second
Video Modes
4K, 1080p, 720p
Optical Sensor Type
13 MP
Focus Adjustment
Automatic
USB-C
Software Certification
Zoom Certified, Google Meet Certified
1 - USB-A to USB-C cable - 1.5 m
1.2 m microphone pick-up range, glass lens, microphone with noise reduction function, RightLight 3 technology, auto exposure control, automatic contrast adjustment, facial recognition for Windows Hello, infrared sensor
3-year warranty
Audio Support
Wired
10.2 cm
2.7 cm
2.7 cm
63 g
Camera
Max Digital Video Resolution
3840 x 2160
Video Modes
4K, 1080p, 720p
Digital Zoom
5
Video Capture
3840 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps , 1280 x 720 @ 90 fps
Image Sensor
13 MP
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
65 - 90
Computer Interface
USB-C
Ports
USB-C - 24-pin USB-C
Attachable mounting clip, privacy shutter
1 x USB-A to USB-C cable - 1.5 m
Graphite
Limited warranty - 3 years
Shipping Width
7.2 cm
Shipping Depth
14 cm
Shipping Height
11.4 cm
Shipping Weight
300 g
Brand: Logitech
