Logitech Brio 4K - Graphite
Quicklinx: J69BWS00 Mfr#: 960-001718
£142.54 ex VAT
£171.04 inc VAT
The Logitech BRIO 4K is a live streaming camera designed for video quality. With a maximum resolution of 3840 x 2160, it captures videos in detail, making it suitable for streaming, conferencing, or content creation. The camera features automatic focus adjustment and offers three field of view settings for versatile framing options during calls or recordings. It incorporates RightLight 3 technology for optimized lighting conditions, ensuring high video quality in challenging environments.
Featuring digital zoom capabilities and a maximum frame rate of 90 fps, the Logitech BRIO delivers smooth streaming experiences. The sound is supported by built-in dual omnidirectional microphones with noise reduction, ensuring clear audio. Certified for use with Zoom and Google Meet, this camera is a reliable tool for work and entertainment. Connectivity is streamlined with a 1.5 m USB-A to USB-C cable, ensuring compatibility with modern devices.
  • High-resolution video capture
    The Logitech BRIO captures video at a maximum resolution of 3840 x 2160, ensuring that every detail is visible and vibrant. This feature is suitable for streaming and video conferencing.
  • Advanced lighting technology
    With RightLight 3 technology, this camera automatically adjusts to varying lighting conditions, presenting your best image in low-light environments.
  • Superior audio quality
    Equipped with built-in dual omnidirectional microphones that reduce noise, this camera ensures that your audio is clear, enhancing communication.
  • Flexible field of view
    The camera offers a range of field of view settings from 65 degrees to 90 degrees, allowing users to customize their frame according to needs.
  • Quick and easy connectivity
    The included 1.5 m USB-A to USB-C cable allows for straightforward setup and compatibility with various devices, enhancing user convenience.
Logitech BRIO 4K - live streaming camera
Live streaming camera
Audio
Yes: built-in dual omni-directional microphones
10.2 cm x 2.7 cm x 2.7 cm
63 g
Graphite
Wired
Camera
Max Resolution
3840 x 2160
Frame Rate (max)
90 frames per second
Video Modes
4K, 1080p, 720p
Optical Sensor Type
13 MP
Focus Adjustment
Automatic
USB-C
Software Certification
Zoom Certified, Google Meet Certified
1 - USB-A to USB-C cable - 1.5 m
1.2 m microphone pick up range, glass lens, microphone with noise reduction function, RightLight 3 technology, auto exposure control, automatic contrast adjustment, facial recognition for Windows Hello, infrared sensor
3-year warranty
Audio Support
Wired
10.2 cm
2.7 cm
2.7 cm
63 g
Camera
Max Digital Video Resolution
3840 x 2160
Video Modes
4K, 1080p, 720p
Digital Zoom
5
Video Capture
3840 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps , 1280 x 720 @ 90 fps
Image Sensor
13 MP
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
65 - 90
Computer Interface
USB-C
Ports
USB-C - 24-pin USB-C
Attachable mounting clip, privacy shutter
1 x USB-A to USB-C cable - 1.5 m
Graphite
Limited warranty - 3 years
Shipping Width
7.2 cm
Shipping Depth
14 cm
Shipping Height
11.4 cm
Shipping Weight
300 g
Brand: Logitech
