The Logitech BRIO 4K is a live streaming camera designed for video quality. With a maximum resolution of 3840 x 2160, it captures videos in detail, making it suitable for streaming, conferencing, or content creation. The camera features automatic focus adjustment and offers three field of view settings for versatile framing options during calls or recordings. It incorporates RightLight 3 technology for optimized lighting conditions, ensuring high video quality in challenging environments.
Featuring digital zoom capabilities and a maximum frame rate of 90 fps, the Logitech BRIO delivers smooth streaming experiences. The sound is supported by built-in dual omnidirectional microphones with noise reduction, ensuring clear audio. Certified for use with Zoom and Google Meet, this camera is a reliable tool for work and entertainment. Connectivity is streamlined with a 1.5 m USB-A to USB-C cable, ensuring compatibility with modern devices.
High-resolution video capture
The Logitech BRIO captures video at a maximum resolution of 3840 x 2160, ensuring that every detail is visible and vibrant. This feature is suitable for streaming and video conferencing. -
Advanced lighting technology
With RightLight 3 technology, this camera automatically adjusts to varying lighting conditions, presenting your best image in low-light environments. -
Superior audio quality
Equipped with built-in dual omnidirectional microphones that reduce noise, this camera ensures that your audio is clear, enhancing communication. -
Flexible field of view
The camera offers a range of field of view settings from 65 degrees to 90 degrees, allowing users to customize their frame according to needs. -
Quick and easy connectivity
The included 1.5 m USB-A to USB-C cable allows for straightforward setup and compatibility with various devices, enhancing user convenience.
- Logitech BRIO 4K - live streaming camera
- Live streaming camera
- Audio
- Yes: built-in dual omni-directional microphones
- 10.2 cm x 2.7 cm x 2.7 cm
- 63 g
- Graphite
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 3840 x 2160
- Frame Rate (max)
- 90 frames per second
- Video Modes
- 4K, 1080p, 720p
- Optical Sensor Type
- 13 MP
- Focus Adjustment
- Automatic
- USB-C
- Software Certification
- Zoom Certified, Google Meet Certified
- Cables Included
- 1 - USB-A to USB-C cable - 1.5 m
- 1.2 m microphone pick up range, glass lens, microphone with noise reduction function, RightLight 3 technology, auto exposure control, automatic contrast adjustment, facial recognition for Windows Hello, infrared sensor
- 3-year warranty
- Audio Support
- Wired
- 10.2 cm
- 2.7 cm
- 2.7 cm
- 63 g
Camera
- Max Digital Video Resolution
- 3840 x 2160
- Video Modes
- 4K, 1080p, 720p
- Digital Zoom
- 5
- Video Capture
- 3840 x 2160 @ 30 fps , 1920 x 1080 @ 60 fps , 1280 x 720 @ 90 fps
Image Sensor
- 13 MP
Lens Construction
- Focus Adjustment
- Automatic
- Diagonal Field of View (degree)
- 65 - 90
- Computer Interface
- USB-C
- Ports
- USB-C - 24-pin USB-C
- Included Accessories
- Attachable mounting clip, privacy shutter
- Cables Included
- 1 x USB-A to USB-C cable - 1.5 m
- Graphite
- Limited warranty - 3 years
- Shipping Width
- 7.2 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 11.4 cm
- Shipping Weight
- 300 g
