Logitech BRIO 100 - Webcam - Graphite
Quicklinx: J1CJWS00 Mfr#: 960-001585
17 In Stock
£32.05 ex VAT
£38.46 inc VAT
Get better video calls with Full HD, auto-light balance, and a built-in mic-plus a privacy shutter.
  • LOOK. SOUND. MEET. BETTER
  • LOOK BETTER. LOOK CLEARER
    Full HD 1080p resolution gives you better clarity for better calls
  • LOOK 50% BRIGHTER
    RightLight boosts brightness by up to 50%, reducing shadows, so you look your best-compared to previous generation Logitech webcams
  • GET FULL PRIVACY
    Thoughtfully designed for your work-from-home life, the integrated privacy shutter gives you reliable privacy. When the day is done, give the shutter a slide for peace of mind
  • SOUND BETTER
    A convenient, built-in microphone ensures that you're heard clearly in video calls, so you can look and sound your best without the fuss
  • PLUG AND PLAY ON YOUR PLATFORM
    Brio 100 is compatible with most calling platforms like Microsoft Teams, Google Meet, and Zoom-and most operating systems like Windows, macOS, and ChromeOS
  • MADE BY LOGITECH
    Logitech is a trusted brand in webcams with decades of design innovation, ensuring high quality and trusted durability
  • MODERN, REFINED COLOR OPTIONS
    An eye-catching design in refined colors allow you to coordinate with your setup and show your personality at work
  • CUSTOMIZE WITH LOGI OPTIONS+ APP
    The easy-to-use app lets you customize visual settings so you can look your best in video calls
Logitech BRIO 100 - webcam
Webcam
Audio
Yes: built-in omni-directional microphone
7.291 cm x 6.664 cm x 3.191 cm
75 g
Graphite
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Video Modes
1080p, 720p
Optical Sensor Type
2 MP
Focus Adjustment
Fixed focus
USB
Software Certification
Certified for Microsoft Teams, Zoom Certified, Google Meet Certified
1 - USB cable - integrated - 1.5 m
Auto-light correction, integrated privacy shutter, RightLight 2 technology, lens with anti-reflex coating
Webcam
Audio Support
Wired
7.291 cm
6.664 cm
3.191 cm
75 g
Camera
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p, 720p
Digital Zoom
1
Video Capture
1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
2 MP
Lens Construction
Focus Adjustment
Fixed focus
Diagonal Field of View (degree)
58
Computer Interface
USB
Clip mount
1 x USB cable - integrated - 1.5 m
Plug and Play, FSC, CarbonNeutral
Graphite
Microsoft Windows, Apple MacOS, Google Chrome OS
Brand: Logitech
