The Bluetooth mouse that gives you the freedom to create anytime and anywhere, on the computer you choose, in all comfort.
CONNECTS TO VIRTUALLY ANY Bluetooth WIRELESS DEVICE
Whether you're a Mac computer addict, use solely Windows or Chrome OS , favor a Windows or Android tablet or switch between them, the M535 simply works -
COMPACT, MOBILE DESIGN
Slip M535 mobile mouse into your bag or pocket so you have it anywhere you need it -
CURVED SHAPE WITH RUBBER GRIP
Comfortable and supportive for your hand, to keep you going for as long as you like -
SMART CONTROL AND EASY NAVIGATION
The convenient navigation button and tilt wheel put control in the palm of your hand. Download Logitech Options software to enable gesture support on Windows and macOS -
Decades of Design Excellence
We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
- Logitech M535 - mouse - Bluetooth 3.0 - blue
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 3.0
- Blue
- 6.11 cm x 10.05 cm x 3.3 cm
- 82 g
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Rubber side grips, battery indicator, scrolling wheel
- Battery
- AA type
- OS Required
- Android 3.2 (Honeycomb) or later, Apple MacOS X 10.8 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
- 2-year warranty
- Mouse
- 6.11 cm
- 10.05 cm
- 3.3 cm
- 82 g
- Blue
Input Device
- Wireless
- Interface
- Bluetooth 3.0
- Max Operating Distance
- Up to 10 m
- Optical
- 1000 dpi
- Included Accessories
- 1 AA battery
- AA type
- Run Time (Up To)
- 10 months
- OS Required
- Limited warranty - 2 years
