The Bluetooth mouse that gives you the freedom to create anytime and anywhere, on the computer you choose, in all comfort.
- Logitech M535 - mouse - Bluetooth 3.0 - grey
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 3.0
- Grey
- 6.11 cm x 10.05 cm x 3.3 cm
- 82 g
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 dpi
- Rubber side grips, battery indicator, scrolling wheel
- Battery
- AA type
- OS Required
- Android 3.2 (Honeycomb) or later, Apple MacOS X 10.8 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
- 2-year warranty
- Mouse
- 6.11 cm
- 10.05 cm
- 3.3 cm
- 82 g
- Grey
Input Device
- Wireless
- Interface
- Bluetooth 3.0
- Max Operating Distance
- Up to 10 m
- Optical
- 1000 dpi
- Included Accessories
- 1 AA battery
- AA type
- Run Time (Up To)
- 10 months
- OS Required
- Limited warranty - 2 years
