Brand
Logitech Bluetooth Mouse M535 - Grey
Quicklinx: CNV0WS00 Mfr#: 910-004530
The Bluetooth mouse that gives you the freedom to create anytime and anywhere, on the computer you choose, in all comfort.
Logitech M535 - mouse - Bluetooth 3.0 - grey
Mouse
Wireless - Bluetooth 3.0
Grey
6.11 cm x 10.05 cm x 3.3 cm
82 g
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips, battery indicator
AA type
Google Chrome OS, Apple MacOS X 10.8 or later, Android 3.2 (Honeycomb) or later, Microsoft Windows 7 / 8 / 10 or later
Mouse
6.11 cm
10.05 cm
3.3 cm
82 g
Grey
Input Device
Wireless
Bluetooth 3.0
Max Operating Distance
Up to 10 m
Optical
Movement Resolution
1000 dpi
1 AA battery
AA type
Run Time (Up To)
10 months
