Logitech Blue Microphones Yeti X - Blackout
Quicklinx: HMCNWS00 Mfr#: 988-000244
£127.70 ex VAT
£153.24 inc VAT
Yeti X has endless versatility to stream and record the way you want. Featuring a 4-capsule array, Yeti X allows you to switch between 4 pickup patterns to dial in the perfect sound for game streaming, Just Chatting, podcasting, interviews, sound effects, voice overs, Discord calls, ASMR and more.
  • BROADCAST FILTERS AND EFFECTS
    Exclusive to Logitech G, Blue VO!CE software helps you develop your own signature vocal sound. Dial in your EQ, protect against clipping with the Limiter and remove "Pops" with the Depopper. Add flavor to your stream with fun vocal effects like pitch shifter, echo, reverb or chorus. Find new ways to express yourself with the included HD audio samples, or even use Yeti X to record your own
  • CUSTOMIZABLE LED LIGHTING
    With G HUB software, you can customize the color of Yeti X's LED lights to match your on-stream aesthetic. And, you can use G HUB to manage your mic gain, headphone volume, monitoring preferences, and pickup pattern selection. G HUB even has settings for your StreamCam webcam and Litra lights, for a complete streaming studio you can control easily from your desktop
  • SMART KNOB FOR SMART RECORDING
    Take control of your on-stream sound with the smart knob, featuring an 11-segment LED voice meter. At a glance, you can check if your voice level is too high or too low and adjust accordingly. A game changer for live streamers, the LED meter allows you to easily maintain professional sound quality with Yeti X while live on camera
  • INNOVATIVE DESIGN MAKES STREAMING EASY
    Yeti X's innovative, yet simple desktop stand enables you to set the perfect angle to pick up your voice. Or, for even more control, you can remove the stand and mount the mic to a boom arm like Compass. Whether you are streaming PvP battles, recording your next YouTube video or just chatting, the iconic shape is instantly recognizable on camera and will inspire your creativity to bring out your best performances
  • INTERNAL SHOCKMOUNT FOR CLEAN SOUND
    Yeti X features an internal shockmount that protects the 4-capsule array during recording so your stream sound is clean
  • PLUG AND PLAY SIMPLICITY
    When inspiration strikes, Yeti X is ready to capture it. Just plug Yeti X straight into your computer or laptop with the included USB cable, and you're all set to record or stream, right away. No drivers required
  • Cardioid
    Cardioid mode captures sound sources that are directly in front of the microphone, delivering rich, full-bodied sound. It's perfect for Twitch streaming, Discord, voice overs and more
  • Omni
    Omni mode picks up sound equally from all around the mic. It's best for capturing the ambience of "being there"-like streaming a multiplayer board game session, Just Chatting with a few guests or hosting a roundtable discussion over Discord
  • Figure 8
    Also known as Bidirectional mode, the Figure 8 pattern records from both the front and rear of the microphone-great for streaming or recording a two-person interview
  • Stereo
    Stereo mode uses both left and right channels to capture a wide, realistic sound image-great for recording sound effects for your stream, an acoustic guitar performance or immersive experiences like ASMR videos
Blue Microphones Yeti X - microphone
Microphone - USB
Compatibility
Mac, Windows
Recommended Use
Professional audio, computer - instrument, vocal, voice, broadcast, recording
Additional Functions
Amplifier, LED lights
Blackout
Microphone
Tabletop
Microphone Technology
Condenser
Microphone Operation Mode
Cardioid / omni-directional / bi-directional / stereo (switchable)
Controls
Mute, volume, gain, blend control
Microphone - USB
Compatibility
Mac, Windows
Dimensions & Weight Details
Microphone: 519 g , Microphone with stand: 11 cm x 12.2 cm x 28.9 cm / 1.28 kg
519 g
Blackout
Recommended Use
Microphone
Recommended Placing
Tabletop
Condenser
Wired
Frequency Response
20 - 20000 Hz
Max Sound Pressure
122 dB
Audio Input Details
Cardioid / omni-directional / bi-directional / stereo (switchable) - 20 - 20000 Hz
Remote Control
Controls
Connector Type
USB , Headphone output (mini-phone 3.5mm)
Microphone stand
Cable Details
USB cable - detachable - 2 m
Brand: Logitech
