Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Logitech Blue Microphones Yeti - 10-Year Anniversary Edition - Blackout
Quicklinx: HJ7SWS00 Mfr#: 988-000229
£95.09 ex VAT
£114.10 inc VAT
Yeti changes the game with endless versatility thanks to its groundbreaking custom mic capsule array. Switch between 4 pickup patterns to dial in the perfect sound for game streaming, podcasting, interviews, music recording, sound effects, voice overs, Discord calls, ASMR and more.
  • POWER FOR YOUR CREATIVITY
    Exclusive to Logitech G, Blue VO!CE software helps you develop your own signature vocal sound. Dial in your EQ, protect against clipping with the Limiter and remove "Pops'' with the Depopper. Add flavor to your stream with fun vocal effects like pitch shifter, echo, reverb or chorus. Find new ways to express yourself with the included HD audio samples, or even use Yeti to record your own
  • STUDIO CONTROLS, RIGHT ON THE MIC
    Yeti features studio controls that put you in charge of every level of the recording process. Monitor your voice through the microphone, latency-free, with the headphone output. Adjust the microphone's sensitivity with the gain control, or take a quick break from the action by tapping the instant mute button
  • INTERNAL SHOCKMOUNT FOR CLEAN SOUND
    Yeti's internal shockmount protects the 3-capsule array and helps keep your content clean and focused on your voice
  • PLUG AND PLAY SIMPLICITY
    When inspiration strikes, Yeti is ready to capture it. Just plug your Yeti microphone straight into your computer or laptop with the included USB cable, and you're all set to record or stream, right away. No drivers required
  • INNOVATIVE DESIGN MAKES STREAMING EASY
    Yeti's innovative, yet simple desktop stand enables you to set the perfect angle to pick up your voice. Or, you can remove the stand and mount Yeti to a desktop boom arm like Compass. Whether you are streaming PvP battles, recording your next YouTube video or just chatting, Yeti's iconic shape is instantly recognizable on camera and will inspire your creativity to bring out your best performances
  • MIC TO MATCH
    Complement your Aurora Collection with a matching Pink Dawn or White Mist Yeti mic
  • Cardioid
    Cardioid mode captures sound from directly in front of the microphone, delivering rich, full-bodied audio. It's perfect for Twitch streaming, podcasting, voice overs and Discord calls
  • Omni
    Omni mode picks up sound equally from all around the mic. It's best for capturing the ambience of "being there"-like streaming a multiplayer board game session, Just Chatting with a few guests or hosting a roundtable discussion over Discord
  • Figure 8
    Also known as Bidirectional mode, the Figure 8 pattern records from both the front and rear of the microphone-great for streaming or recording a two-person interview
  • Stereo
    Stereo mode uses both left and right channels to capture a wide, realistic sound image-great for recording sound effects for your stream, an acoustic guitar performance or immersive experiences like ASMR videos
Blue Microphones Yeti - 10-Year Anniversary Edition - microphone
Microphone - USB
Compatibility
Mac, Windows
Recommended Use
Professional audio, computer - instrument, vocal, voice, broadcast, recording
Additional Functions
Amplifier
Blackout
Microphone
Tabletop
Microphone Technology
Condenser
Microphone Operation Mode
Cardioid / omni-directional / bi-directional / stereo (switchable)
Controls
Mute, volume, gain control
Microphone - USB
Compatibility
Mac, Windows
Amplifier
Dimensions & Weight Details
Microphone: 550 g , Microphone with stand: 12 cm x 12.5 cm x 29.5 cm , Microphone stand: 1 kg
550 g
Blackout
Recommended Use
Microphone
Recommended Placing
Tabletop
Condenser
Wired
Sensitivity
4.5 mV/Pascal
Frequency Response
20 - 20000 Hz
Total Harmonic Distortion (THD)
0.5%
Max Sound Pressure
120 dB
Audio Input Details
Cardioid / omni-directional / bi-directional / stereo (switchable) - 20 - 20000 Hz
Remote Control
Controls
Connector Type
USB , Headphone output (mini-phone 3.5mm)
Microphone stand
Cable Details
USB cable - detachable
Plug and Play
Brand: Logitech
