Add a USB conference camera to this pre-configured bundle to deploy Microsoft Teams Rooms through the workplace. This bundle includes: Logitech Tap touch controller with 10.1" screen, Proximity Join, and HDMI input for wired content sharing; Microsoft-approved Intel NUC mini-PC with Windows 10 IoT Enterprise SAC and Teams Rooms image; Logitech PC Mount with cable retention; Logitech JumpStart support resources (90-days).
Microsoft Teams Room Licenses sold separately.
Effortless integration
The Logitech BASE Microsoft Teams Rooms (no AV) with Tap + Intel NUC is designed for seamless integration into any meeting space. With a bundled Intel NUC and Logitech JumpStart support for 90 days, setting up and maintaining your video conferencing system has never been easier. -
Advanced connectivity
Featuring a SuperSpeed USB 3.0 and HDMI interface, this video conferencing kit ensures high-speed, reliable connections for all your peripherals. The inclusion of a 10 m SuperSpeed USB cable provides flexibility in setup and placement. -
Optimized for interaction
The 10.1" touchscreen comes with a 1280 x 800 resolution, anti-glare, and oleophobic coating, offering a clear, smudge-resistant interface for effortless control during meetings. -
Certified performance
Certified for Microsoft Teams and compliant with DisplayLink Plug-and-Play standards, this system delivers a reliable, high-quality video conferencing experience tailored for professional use.
- Logitech BASE Microsoft Teams Rooms (no AV) with Tap + Intel NUC - video conferencing kit - with Intel NUC, Logitech JumpStart (90 days)
- Video conferencing kit
- 24.4 cm x 17.9 cm x 5.8 cm
- 1.25 kg
- Input Device
- 10.1" touchscreen (wired)
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Bundled with
- Intel NUC, Logitech JumpStart (90 days)
- 24.4 cm
- 17.9 cm
- 5.8 cm
- 1.25 kg
- Enclosure Colour
- Graphite
- Bundled with
Input Device
- 10.1" touchscreen
- Connectivity Technology
- Wired
- Oleophobic coating, anti-glare coating, 1280 x 800 resolution
- 1 x SuperSpeed USB 3.0 , 1 x audio / video - HDMI
- Cables Included
- SuperSpeed USB cable - 10 m
- Included Accessories
- Mounting bracket
- DisplayLink Plug and Display
- Limited warranty - 2 years
