Logitech B530 USB Headset MS Lync Optimised
Quicklinx: 7WLCWS00 Mfr#: 981-000336
With laser-tuned drivers and a built-in equalizer, your professionals get clear, comfortable, effective communication. Optimized for Microsoft® Lync™ 2010.
Laser-tuned drivers
Laser-tuned drivers minimize distortion, delivering natural audio for crystal clear conversations.
Built-in equalizer
The equalizer is optimized for conversations, making it easy to hear and be heard.
Noise-canceling unidirectional microphone
Reduces background noise for clearer conversations.
Flexible, rotating boom
The adjustable microphone rotates out of the way when not in use.
Padded headband and ear cups
An adjustable padded headband and pivoting ear cups with leatherette pads keep this headset comfortable, even during long conference calls.
Easy setup
Your employees can just plug it in--and start using it. No software or pairing required.
Quick-access audio controls
Answer and end calls, adjust the volume and mute the microphone right from the headset--with no dangling, in-line controls to get in the way.
It's optimized for Lync 2010, so your organization can capitalize on teleconferencing and unified communications.
Made to last
The headset comes with a three-year limited hardware warranty.
  • Laser-tuned drivers
  • Built-in equalizer
  • Noise-canceling unidirectional microphone
    The noise-canceling unidirectional microphone reduces background noise for clearer conversations.
  • Flexible, rotating boom
  • Padded headband and ear cups
  • Easy setup
    Your employees can just plug it in - and start using it. No software or pairing required.
  • Quick-access audio controls
    Answer and end calls, adjust the volume and mute the microphone right from the headset - with no dangling, in-line controls to get in the way.
  • Optimized for Microsoft Lync
    It's optimized for Lync, so your organization can capitalize on teleconferencing and unified communications.
Manufacturer
Logitech
Model
B530 USB Headset
Wired
Headset
Headphones
Headset Type
Ear-cup
Earcover
Binaural
Recommended Use
PC multimedia
Audio Input / Microphone Operation Mode
Mono
Audio Input / Sensitivity
-42 dBV/Pascal
Audio Output / Sound Output Mode
Stereo
Audio Output / Response Bandwidth
20 - 20000 Hz
Service & Support / Type
3 years warranty
