The Logitech B525 HD Webcam allows you to enjoy clear, 720p HD video calling from either your laptop or on top of your monitor, using your favorite video applications (including Microsoft Lync and Skype). This HD webcam gives you a superior video calling experience at an affordable price.
HIGH-QUALITY IMAGE AND SOUND
Image quality is important for your business meetings. The affordable B525 HD Webcam, with its 720p HD video captured at 30 frames per second, delivers clear images even in low-light conditions. Built-in autofocus maintains sharpness as close as 10 cm -
EASY TO SET UP AND USE
Plug and play to start every meeting on time. The B525 HD Webcam works with popular video conferencing software, including Skype and Skype for Business. The convenient fold-and-go design lets you pack the camera and take it with you. Just attach it to your laptop and begin your meeting
- Logitech HD Webcam B525 - webcam
- Webcam
- Audio
- Yes: built-in microphone
- 6.6 cm x 2.9 cm x 4 cm
- 88 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Focus Adjustment
- Automatic (min distance 10 cm)
- USB 2.0
- Cables Included
- 1 - USB cable - 1.5 m
- USB 2.0 compatibility, RightLight 2 technology, 720p HD video calls, Skype compatible
- 3-year warranty
- Webcam
- Audio Support
- Wired
- 6.6 cm
- 2.9 cm
- 4 cm
- 88 g
Camera
- Max Digital Video Resolution
- 1920 x 1080
- Video Capture
- 1280 x 720 , 1920 x 1080
Lens Construction
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
- Computer Interface
- USB 2.0
- Interfaces Details
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Flat panel monitor clip
- Cables Included
- 1 x USB cable - 1.5 m
- Plug and Play
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Limited warranty - 3 years
