Logitech B330 Silent Plus Mouse
Quicklinx: CG42WS00 Mfr#: 910-004913
With great noise reduction, B330 Silent Plus offers a quiet experience for yourself and those around you. It has a long-lasting battery life with auto-sleep and a powerful wireless range with 128-bit encryption between the mouse and the receiver. Plus, it's designed with contoured grips made of soft rubber for total comfort. Just plug the tiny USB receiver. Finally, the Logitech advanced optical tracking guarantees smooth and precise moves on almost any surface.
  • Enjoy the sound of silence
    The click feels the same. But the experience is completely different to you and your colleagues. Silent Mice offer over 90% noise reduction on the click sound. Durable feet made of high performance material and a rubber wheel provide quiet gliding and scrolling. Studies show that fewer distractions contribute to a healthier and more productive environment, especially key for open offices
  • Crafted for your right hand
    Designed with curved lines that provide a place to rest your thumb and improve control
  • 24-month battery life
    Stay powered up and ready to roll even while on the road. Thanks to energy efficient engineering, you can work longer between battery changes. B330 SILENT PLUS automatically puts itself to sleep when not in use
  • Simple. Reliable. Strong
    Enjoy a wireless connection up to 10m away thanks to a plug-and-forget nano receiver. B330 SILENT PLUS features Logitech Advanced Optical Tracking for ultra precise moves on almost any surface. No hassle, no software needed. Works with Windows , Mac, Chrome OS or Linux -based computers
  • Quiet Mark Certification
    Logitech is the first mouse company in the world to receive the Quiet Mark certification. This international mark of approval award program from the UK Noise Abatement Society recognizes technology designed to reduce noise
Logitech B330 Silent Plus - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
6.79 cm x 10.54 cm x 3.84 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, Nano wireless receiver
AA
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Linux Kernel 2.6
Mouse
Wireless Receiver
6.79 cm
10.54 cm
3.84 cm
91 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
AA
Run Time (Up To)
24 months
