Logitech B110 Optical USB Mouse
Quicklinx: 5L9TWS00 Mfr#: 910-001246
Go with the mouse experts for built-in quality and durability. You'll gain comfort and precision - and raise the bar on productivity.
  • Precise cursor control
    With 800 dpi sensitivity, you'll get precise cursor control so you can edit documents and navigate the web more efficiently.
  • Comfortable, ambidextrous shape
    Feel good in either hand, so you feel more comfortable as you work - even at the end of the day.
  • Side-to-side scrolling plus zoom
    Instantly zoom in and out. Scroll horizontally and vertically.
  • Zero setup
    Just plug it into your USB port and get started right away.
Logitech B110 - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
