Logitech B100 Optical Mouse for Business White
Quicklinx: 8YW1WS00 Mfr#: 910-003360
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wired
Colour: White
Compatibility: Unix, Mac, PC
29 In Stock
£8.31 ex VAT
£9.97 inc VAT
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
  • 800 dpi optical precision
  • Zero setup
  • Comfort in hand
  • Smooth operator
Logitech B100 - mouse - USB - white
Mouse
Wired - USB
White
Orientation
Right and left-handed
6.17 cm x 11.3 cm x 3.84 cm
85 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.17 cm
11.3 cm
3.84 cm
85 g
White
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Shipping Width
4.2 cm
Shipping Depth
8.7 cm
Shipping Height
13.2 cm
Shipping Weight
109 g
Limited warranty - 3 years
Type: Mouse
Colour: White
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
Brand: Logitech
