Logitech B100 Optical Mouse Black
Quicklinx: 8YW0WS00 Mfr#: 910-003357
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC, Unix
More than 50 In Stock
£8.68 ex VAT
£10.41 inc VAT
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
  • Comfortable, ambidextrous design
    The comfortable, lower-profile shape feels good in either hand-even after a long day of work
  • 800 dpi optical precision
  • Zero setup
    It works right out of the box-you just plug it into your USB port and you're ready for business
  • Built by Logitech
    This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer
  • Comfort in hand
  • Smooth operator
  • Ready in no time
    This plug-and-play mouse is simple to set up-you just plug it in to your USB and get back to business
Logitech B100 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.17 cm x 11.3 cm x 3.84 cm
85 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.17 cm
11.3 cm
3.84 cm
85 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Shipping Width
4.2 cm
Shipping Depth
8.7 cm
Shipping Height
13.2 cm
Shipping Weight
109 g
Limited warranty - 3 years
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Brand: Logitech
