Looks like an iPad, feels like a laptop
Let's turn your iPad into a laptop. Comfortably-spaced keys. The ideal, concave, key shape. A familiar layout you won't have to 're-learn.' And a dedicated row of speedy iOS shortcuts -
Designed for typing and tapping
The keys have plenty of room, yet the screen is still right at your fingertips for fluid interaction. iPad doesn't bounce or tip over when you tap. It's just one idea after another -
Smart power management
A mobile, Bluetooth keyboard should have enough power to last, and smarts to conserve. We like that idea.- iPad and Type+ both automatically turn on when you need them and off when you don't - Get up to 3 months of battery life on a single charge Based on average use of two hours per day -
Two cases in one
It's a keyboard case when you need to type and not when you don't- Typing mode sets ideal viewing angle for both typing and screen interaction. Typing mode automatically turns keyboard on. - Lay-flat reading mode automatically turns keyboard off -
Lightweight, but serious about protection
The idea of incredibly thin and light also means protection against bumps, scratches and spills. Convenient, huh
- Logitech Type+ - keyboard and folio case - UK - carbon black Input Device
- Keyboard and folio case
- Interface
- Bluetooth
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Carbon black
- 25.59 cm x 18.34 cm x 1.81 cm
- 405 g
- 2-year warranty
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
- Wireless
- UK
- 25.59 cm
- 18.34 cm
- 1.81 cm
- 405 g
Carrying Case
- Scratch-proof, transformable into a stand for typing or viewing video, spill-resistant, dual-mode positioning, sleep/wake function, SecureLock system
- Carbon black
- Limited warranty - 2 years
