LiteOn IHOS104 4x SATA Internal BD-ROM Drive Bare (Includes Power DVD Software)
Quicklinx: 80WFWS00 Mfr#: IHOS104-06
  • BD-ROM
Lite-On 4x Internal BD-ROM Drive is compatible with Blu-Ray, DVD and CD formats to ensure optimal playback possibilities
Key Features
  • Higher transfer rates with SATA connection (compared to PATA)
  • Future proof; compatibility with the latest motherboards
  • Better airflow in PC casings due to smaller cable and plug sizes
  • SATA supports "hot swap" (must be supported by your motherboard)
  • Enjoy High Definition Blu-ray movies.
Lite-On BD-ROM drives offer the best solution for people who want to enjoy High Definition Blu-ray movies at an affordable cost. Besides Blu-ray movies, your current DVD and CD collections can also be played. Lite-On BD-ROM drives are compatible with Blu-ray, DVD and CD formats to ensure optimal playback possibilities. The fully featured Lite-On iHOS104 BD-ROM drive features the latest optical storage technologies.
LiteOn iHOS104 - BD-ROM drive - Serial ATA - internal
BD-ROM drive - internal
Serial ATA
14.58 cm x 18 cm x 4.14 cm
0.8 kg
Optical Storage
BD-ROM - 5.25" x 1/2H
Read Speed
40x (CD) / 12x (DVD±R) / 8x (DVD±R DL) / 4x (BD-R)
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.58 cm
18 cm
4.14 cm
0.8 kg
Optical Storage
Read Speed
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, DVD-Video
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM
Media Load Type
Tray
Access Time
160 ms (DVD), 160 ms (CD), 160 ms (BD)
Buffer Size
2 MB
True Theater High Definition Technology (TTHD)
Video CD
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
60,000 hour(s)
Package Type
OEM
Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
5 °C
50 °C
8 - 80%
