A fast reliable SATA DVD writer packed with optical drive technology for accurate disc writing at high speeds. This DVD burner reduces the time it takes to reliably secure your business files, backup your personal files, or create your DVD videos.
SMARTwrite 24x gives fast DVD writing speed and ensures that every disc is burned at its maximum possible speed by learning about the performance of each disc and brand of media. This reduces the time for disc burns and allows some brands of media to be safely burned at higher that their specified speeds.
SATA interface technology increases drive performance by improving data transfer rates and efficiency over older PATA/IDE interfaces. Also featured is SMART-Burn, a Lite-On system that gives you exceptional burn quality by using the optimum writing technique for each disc.
The iHAS324 is a high performance DVD burner, with a fast SATA interface and SMART technology for accuracy, making it an idea DVD burner for your home or business PC.
- LiteOn iHAS324 - DVD±RW (±R DL) - Serial ATA - internal
- DVD±RW (±R DL) - internal
- Black
- Interface
- Serial ATA
- 14.5 cm x 17 cm x 4.1 cm
- 0.9 kg
- Optical Storage
- DVD±RW (±R DL) - 5.25" x 1/2H
- Read Speed
- 48x (CD) / 16x (DVD)
- Write Speed
- 48x (CD) / 24x (DVD±R) / 8x (DVD±R DL)
- CD / DVD Rewrite Speed
- 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW)
- Buffer Underrun Protection
- SMART Burn
- Media Load Type
- Tray
- Microsoft Certification
- Compatible with Windows 7
- Black
- Interface
- Serial ATA
- 14.5 cm
- 17 cm
- 4.1 cm
- 0.9 kg
Optical Storage
- Read Speed
- Write Speed
- Supported Recording Modes
- Multisession, disc-at-once, track-at-once, session-at-once, restricted overwrite, random access write, incremental recording, multi-border recording, sequential write, Layer Jump Recording (LJR)
- Supported Media Formats
- CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Media Load Type
- Tray
- Access Time
- 160 ms (DVD), 140 ms (CD)
- Buffer Size
- 2 MB
- SMART Burn
- SMART-X, SmartErase, Auto Balance System (ABS), Super AllWrite
- Video CD
- 1 x - 7 pin Serial ATA
- Compatible Bay
- 1 x 5.25" x 1/2H - front accessible
- MTBF
- 70,000 hour(s)
- Package Type
- Retail
- OS Required
- Microsoft Windows Vista / 2000 / XP
- System Requirements Details
- Pentium 4 - 1.3 GHz - RAM: 128 MB - HDD: 650 MB
- 5 °C
- 50 °C
- 15 - 80%
