LiteOn IHAS120-04 20x SATA Super AllWrite Internal Half-Height DVDRW - Black
Quicklinx: 8HLMWS00 Mfr#: IHAS120-04
This DVD writer provides professional-quality DVD and CD performance for writing, rewriting and reading. It supports Running OPC (ROPC). In addition, the drive is equipped with buffer underrun technology to eliminate buffer underrun errors, so you can safely use your computer for other things while you're writing to DVD or CD, and using a web connection, you can update this drive's flash memory to the latest firmware revisions without opening the drive.
LiteOn IHAS120 20X DVD±RW (Dual ±R)/RAM SATA Drive (Internal, Bare, Black)
  • Type - Half Height (HH) Internal Combination Drive
  • Interface - SATA
  • Support Double Layer DVD+/- R9 Recording Function
  • Features - SMART-BURN + SMART-X functions
  • Support both 8cm and 12cm disc of CD and DVD family
  • SATA interface, Half-Height internal DVD+R / DVD+RW / DVD-R / DVD-RW / DVD+R9/ DVD-R9/ DVD-RAM/ DVD-ROM / CD-R/ CD-RW / CD-ROM combination drive
  • Support Double Layer DVD+/- R9 Recording Function 
  • SMART-BURN function Automatically adjusting writing strategy & walking OPC to provide the best burning quality 
  • SMART-X(*) function adjusts CD-DA / VCD / DVD data extraction to a fastest allowable speed according to both data request rate from host and disk quality 
  • Support Fixed Packet, Variable Packet, TAO, SAO, DAO, Random Access Write, Incremental, sequential recording, restricted overwrite, Layer Jump recording, Raw Mode Burning & Over-Burn 
  • DVD read compliant: DVD single/dual layer (PTP/OTP), DVD-R, DVD-R multi-borders, DVD-RAM DVD+R, DVD+R multi-sessions, DVD-RW, and DVD+RW 
  • CD read compliant: CD-DA, CD-ROM, CD-ROM/XA, Photo-CD, Multi-session, Karaoke-CD, Video-CD, CD-I FMV, CD Extra, CD Plus, CD-R, and CD-RW 
  • Support both 8cm and 12cm disc of CD and DVD family 
  • Conform to Orange Book: Part 2 CD-R Volume 1, Part 2 CD-R Volume 2 Multi Speed, 
  • Supported transfer mode: PIO mode 4, DMA mode 2 and Ultra DMA mode 5
Specifications
DVD Family
Write
  • DVD+R 20X maximum by CAV
  • DVD-R 20X maximum by CAV
  • DVD+R9 12 maximum by CAV
  • DVD-R9 12 maximum by CAV DVD-RAM 12X maximum by PCAV
ReWrite
  • DVD+RW 8X by CLV
  • DVD-RW 6X by CLV
Read
  • 16X maximum by CAV
  • Rand. Access Time 160ms 
CD Family
  • Write CD-R 48X by CAV
  • ReWrite CD-RW 24X maximum by Z-CLV in UltraSpeed disc
  • Read 40X maximum by PCAV
  • Rand. Access Time 140ms 
  • Buffer Size : 0.5 MB(MAX) 
Spec
  • PC Required : Pentium 4 1.3GHz or higher CPU and 128MB or higher RAM are required
  • HDD must have access time < 20 ms; with a minimum of 650MB free space
  • 9GB free space for creating a DVD image file (9GB for double layer; 5GB for single layer) 
  • Compatibility : Windows 8/ 7 / XP / 2003 / Vista and Linux 
  • MTBF(Life) : 70000 POH at 25% duty cycle in room temp. 
  • S/N Ration : >75dB 
  • Environment : Operating 5C to 50C; Relative Humidity: 20% to 80% / Non-Operating -40C to 65C; Relative Humidity: 5% to 95% 
  • Dimension : 146(W) x 41.3(H) x 170(D) ( +/- 0.5 mm) 
  • SMART-X : Smart Monitoring & Adjusting Read-speed Technology for eXtraction.
LiteOn iHAS120 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.5 cm x 17 cm x 4.1 cm
0.9 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 20x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.5 cm
17 cm
4.1 cm
0.9 kg
Optical Storage
Read Speed
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, packet writing, session-at-once, restricted overwrite, random access write, sequential write, Layer Jump Recording (LJR)
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
Buffer Size
2 MB
SMART Burn
SMART-X, Auto Balance System (ABS), Smart-Write
Video CD
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
70,000 hour(s)
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 2003
System Requirements Details
Pentium - 166 MHz - RAM: 128 MB - HDD: 650 MB
5 °C
50 °C
15 - 80%
