LiteOn DVD-RW 24x SATA LightScribe LabelTag - Retail Box
Quicklinx: 79SWWS00 Mfr#: IHAS624-32
The iHAS624 is a fast and reliable SATA DVD writer with various disc labeling techniques as well as SmartErase for safe and permanent disc erasing. The drive is designed for DVD writing at 24x and features the latest optical drive technologies for accurate disc writing. This DVD Writer reduces the time it takes to reliably secure business files, backup personal files or create DVD videos.
Using LabelTag means a convenient and cost-effective way for labeling any DVD±R single layer disc without using additional software. LabelTag is a patented LiteOn feature that allows users to create a circular label on the data discs. When creating the disc, users can add text and/or images printed on the same side of the disc where the data is stored. No need to use markers, stickers, or even the hassle of flipping the disc. There is no special media required and the disc remains fully compatible with other playback devices.
Additionally, users can choose to label their discs with LightScribe technology. With LightScribe one can directly create customized labels and burn them onto LightScribe compatible DVDs and CDs.
The iHAS624 offers fast DVD±R writing speed: 24x. The writing speed for double layer DVD±R discs and DVD-RAM is 12x, while writing speeds for rewritable media are 8x for DVD +RW and 6x for DVD-RW.
  • 24x powered by SmartWrite
    SmartWrite can overspeed certain 16x DVD±R media to a maximum of 24x. Always burn with the highest speed and best quality. SmartWrite optimizes the writing strategy for each particular session and automatically memorizes this for future sessions.
  • LabelTag technology
    Print simple circular labels on the data side of your discs. Burn simultaneously with your data. LabelTag works with all standard DVD±R discs.
  • Super AllWrite
    Super AllWrite is the compatibility standard from LiteOn to offer the ability to read, write and re-write to any disc format on the market.
  • LightScribe
    Kiss your marker goodbye. Burn custom labels directly to CDs and DVDs using LightScribe. Flip and burn. Create silkscreen-quality images on CDs or DVDs. After you burn content, just flip the disc, reinsert and burn your label.
  • SmartErase technology
    Erase your disc the "Smart way": cost effective and beyond recovery. Throw away your useless discs without any worries.
  • Serial ATA (SATA) connectivity
    Higher transfer rates with SATA connection. Future proof; compatibility with the latest motherboards. Better airflow in PC casings due to smaller cable and plug sizes.
LiteOn iHAS624 - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.6 cm x 17 cm x 4.2 cm
0.7 kg
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 24x (DVD±R) /12x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Disc Labeling Technology
LightScribe Technology, LabelTag
Media Load Type
Tray
Serial ATA
14.6 cm
17 cm
4.2 cm
0.7 kg
Optical Storage
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
160 ms (DVD), 140 ms (CD)
Buffer Size
2 MB
SmartErase, Smart-Write, Super AllWrite
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
MTBF
70,000 hour(s)
Package Type
Retail
Microsoft Windows XP, Microsoft Windows 2000 SP4, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium 4 - 1.3 GHz - RAM: 128 MB - HDD: 650 MB
5 °C
50 °C
15 - 80%
