LiteOn 8x Slim Top Load Ext. DVDRW
Quicklinx: 73C2WS00 Mfr#: ETAU108-02
LiteOn Top Loading Slimline DVDRW Drive - The Ideal Travel Accessory, Archive Your Movies, Photos, and Music Anytime
Key Features
External Top Loader Design
USB bus-powered
Super AllWrite
USB 2.0 connectivity
Lite-On External Top-Load DVD/CD Writers are extremely portable and compatible with CD, DVD and Double Layer DVD formats (up to 8,5 GB).
With these Lite-On External Top-Load DVD/CD Writers users can burn files to discs, install software, listen to their music CDs, and watch DVD movies on the go. No power adapter needed!
The eTAU108 features a unique top loading mechanism, which is not only ergonomic, but also offers stability and reliability during long time operation.
The fully featured Lite-On eTAU08 drive comes with the latest optical storage technologies.
  • USB bus-powered
    No power adapter needed! Your notebook is your power source. Supports power saving mode.
  • USB 2.0 connectivity
    Higher transfer rates with USB 2.0 connection. The external USB 2.0 interface allows you to easily connect to any PC, anywhere.
  • Super AllWrite
    Super AllWrite is the compatibility standard from Lite-On to offer the ability to read, write and re-write to any disc format on the market.
  • SMART-BURN
    SMART-BURN is a technology developed by Lite-ON. It can automatically adjusting writing strategy and running OPC to provide the best burning quality and avoid Buffer Under Run error as well.
LiteOn eTAU108 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
USB 2.0
14.5 cm x 15.6 cm x 2.1 cm
0.35 kg
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Top-load
Microsoft Certification
Compatible with Windows 7
USB 2.0
14.5 cm
15.6 cm
2.1 cm
0.35 kg
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Media Formats
CD-DA (audio)
Media Load Type
Top-load
Access Time
110 ms (CD), 130 ms (DVD)
Buffer Size
2 MB
SMART Burn
SMART-X, Auto Balance System (ABS), Super AllWrite
1 x USB 2.0
MTBF
60,000 hour(s)
Package Type
Retail
Microsoft Windows XP, Microsoft Windows 2000 SP4, Microsoft Windows Vista
System Requirements Details
Windows 2000/XP/Vista - Pentium - 166 MHz - RAM: 128 MB - HDD: 100 MB
5 °C
35 °C
10 - 80%
