LiteOn Top Loading Slimline DVDRW Drive - The Ideal Travel Accessory, Archive Your Movies, Photos, and Music Anytime
Key Features
External Top Loader Design
USB bus-powered
Super AllWrite
USB 2.0 connectivity
Lite-On External Top-Load DVD/CD Writers are extremely portable and compatible with CD, DVD and Double Layer DVD formats (up to 8,5 GB).
With these Lite-On External Top-Load DVD/CD Writers users can burn files to discs, install software, listen to their music CDs, and watch DVD movies on the go. No power adapter needed!
The eTAU108 features a unique top loading mechanism, which is not only ergonomic, but also offers stability and reliability during long time operation.
The fully featured Lite-On eTAU08 drive comes with the latest optical storage technologies.
USB bus-powered
No power adapter needed! Your notebook is your power source. Supports power saving mode. -
Higher transfer rates with USB 2.0 connection. The external USB 2.0 interface allows you to easily connect to any PC, anywhere. -
Super AllWrite
Super AllWrite is the compatibility standard from Lite-On to offer the ability to read, write and re-write to any disc format on the market. -
SMART-BURN
SMART-BURN is a technology developed by Lite-ON. It can automatically adjusting writing strategy and running OPC to provide the best burning quality and avoid Buffer Under Run error as well.
- LiteOn eTAU108 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
- DVD±RW (±R DL) / DVD-RAM drive - external
- Black
- Interface
- USB 2.0
- 14.5 cm x 15.6 cm x 2.1 cm
- 0.35 kg
- Optical Storage
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Buffer Underrun Protection
- SMART Burn
- Media Load Type
- Top-load
- Microsoft Certification
- Compatible with Windows 7
- Black
- Interface
- USB 2.0
- 14.5 cm
- 15.6 cm
- 2.1 cm
- 0.35 kg
Optical Storage
- Read Speed
- Write Speed
- Supported Media Formats
- CD-DA (audio)
- Media Load Type
- Top-load
- Access Time
- 110 ms (CD), 130 ms (DVD)
- Buffer Size
- 2 MB
- SMART Burn
- SMART-X, Auto Balance System (ABS), Super AllWrite
- 1 x USB 2.0
- MTBF
- 60,000 hour(s)
- Package Type
- Retail
- OS Required
- Microsoft Windows XP, Microsoft Windows 2000 SP4, Microsoft Windows Vista
- System Requirements Details
- Windows 2000/XP/Vista - Pentium - 166 MHz - RAM: 128 MB - HDD: 100 MB
- 5 °C
- 35 °C
- 10 - 80%
