LiteOn 8x DVD-RW USB2 Slim White Drive
Quicklinx: 73P0WS00 Mfr#: ESAU108-104
Marketing description is not available.
  • USB bus-powered
    No power adapter needed! Your notebook is your power source. It supports power saving mode.
  • USB 2.0 connectivity
    It has higher transfer rates with USB 2.0 connection. The external USB 2.0 interface allows you to easily connect to any PC, anywhere.
  • Super AllWrite
    Super AllWrite is the compatibility standard from Lite-On to offer the ability to read, write and re-write to any disc format on the market. Use your DVD writer for any purpose with the media you desire. Purchase your media without hassle; you no longer have to worry about compatibility.
  • SMART-BURN
    SMART-BURN is a technology developed by Lite-ON. It can automatically adjusting writing strategy and running OPC to provide the best burning quality and avoid Buffer Under Run error as well.
  • Smart-X
    SMART-X(2) function adjusts CD-DA/VCD/DVD data extraction to a fastest allowable speed according to both data request rate from host and disc quality.
  • ABS system
    ABS system reduces vibration and noise during recording and reading.
LiteOn eSAU108 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
Pearl white
USB 2.0
14.5 cm x 15.6 cm x 2.1 cm
0.35 kg
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Buffer Underrun Protection
SMART Burn
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Pearl white
USB 2.0
14.5 cm
15.6 cm
2.1 cm
0.35 kg
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Recording Modes
Multisession, disc-at-once, track-at-once, packet writing, session-at-once
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Media Load Type
Tray
Access Time
110 ms (CD), 130 ms (DVD)
Buffer Size
2 MB
SMART Burn
SMART-X, Auto Balance System (ABS), Super AllWrite
Video CD
1 x USB 2.0
MTBF
60,000 hour(s)
Package Type
Retail
Microsoft Windows XP, Microsoft Windows 2000 SP4, Microsoft Windows Vista
System Requirements Details
Windows 2000/XP/Vista - Pentium - 166 MHz - RAM: 128 MB - HDD: 100 MB
5 °C
35 °C
10 - 80%
