Complete connectivity
With 2 full-size USB ports, the Linx 1020 lets you connect all your external devices without the need for additional hubs or cables. Whether you need files from your external HDD, prefer to use a mouse when working, or just want to plug in your Xbox 360 controller for a better gaming experience, the Linx 1020 lets you work and play the way you want to. -
Blockbuster gaming
The Linx 1020 takes blockbuster games and places them in your hands. From casual gaming to intense multiplayer scenarios, enjoy great gaming experiences.
- Linx 1020 - 10.1" - Intel Atom x5 - Z8300 - 2 GB RAM - 32 GB eMMC - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Windows 10 Home
- Processor
- Intel Atom x5 Z8300 / 1.44 GHz, up to 1.84 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L
- Storage
- 32 GB eMMC
- Display
- 10.1" touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 7 hours
- G-sensor
- Dimensions (WxDxH) - tablet
- 25.5 cm x 16.5 cm x 1.02 cm
- 640 g
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.84 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 2 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Rated Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 10.1" - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Capacitive touch screen
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Sound
- Stereo speakers, microphone
Input
- Keyboard Layout
- UK
- Multi-gesture trackpad
Communications
- Wireless
- Technology
- Lithium Ion
- Capacity
- 7000 mAh
- Run Time
- Up to 7 hours
AC Adapter
- Output
- 5 V, 2 A
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , Micro-USB 2.0 , Micro-HDMI , Headphone output
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Integrated Options
- G-sensor
- Included Accessories
- Power adapter, keyboard
- Cables Included
- Micro-USB cable
- WEEE
- 640 g
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
