Linx 810B 8" Intel Atom Z3735G 1GB 32GB Windows 10
Quicklinx: BL4ZWS00 Mfr#: LINX810B
  • Atom
  • IEEE 802.11n
  • Bluetooth 4.0
The Linx 810 is perfect for limitless creativity and productivity wherever you are. Powerful and portable, your entertainment and documents come to life on the beautifully precise display powered by a Quad-Core Intel processor.
With Windows 10 everything is so familiar and easy to use, you'll feel like an expert straight from the box. Great apps come as standard with the pre-installed office mobile apps and the Windows store that brings a unified shopping experience across all Windows 10 devices so that you can easily purchase apps, games, music, movies, and TV programs.
Linx 810 - 8" - Intel Atom - Z3735F - 1 GB RAM - 32 GB SSD
Tablet - no keyboard
Operating System
Windows 10 Home
Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
1 GB
Storage
32 GB SSD
Display
8" touchscreen 1280 x 800 / WXGA
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
Up to 7 hours
G-sensor
21.5 cm x 12.5 cm x 0.89 cm
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
1.83 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
1 GB
Storage
Main Storage
32 GB SSD
Display
8" - IPS
Touchscreen
Yes (10-point multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Audio & Video
Camera
Yes - 720p
Resolution
2 Megapixel (rear), 2 Megapixel (front)
Communications
Wireless
Wi-Fi Direct
DLNA CERTIFIED
Lithium Ion
4000 mAh
Run Time
Up to 7 hours
Connections & Expansion
Slots
1 x microSD
Micro-HDMI , Micro-USB 2.0 , Headphone output
Memory Card Reader
Yes (microSD)
Software
Software Included
Word Mobile, Excel Mobile, PowerPoint Mobile
Integrated Options
G-sensor
Capacitive touch screen
Power adapter
Micro-USB to USB cable
