The Linx 810 is perfect for limitless creativity and productivity wherever you are. Powerful and portable, your entertainment and documents come to life on the beautifully precise display powered by a Quad-Core Intel processor.
With Windows 10 everything is so familiar and easy to use, you'll feel like an expert straight from the box. Great apps come as standard with the pre-installed office mobile apps and the Windows store that brings a unified shopping experience across all Windows 10 devices so that you can easily purchase apps, games, music, movies, and TV programs.
- Linx 810 - 8" - Intel Atom - Z3735F - 1 GB RAM - 32 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Windows 10 Home
- Processor
- Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
- Memory
- 1 GB
- Storage
- 32 GB SSD
- Display
- 8" touchscreen 1280 x 800 / WXGA
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Battery
- Up to 7 hours
- G-sensor
- Black
- 21.5 cm x 12.5 cm x 0.89 cm
- Product Type
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 1 GB
Storage
- Main Storage
- 32 GB SSD
Display
- 8" - IPS
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
Audio & Video
- Camera
- Yes - 720p
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
Communications
- Wireless
- Wi-Fi Direct
- DLNA CERTIFIED
- Technology
- Lithium Ion
- Capacity
- 4000 mAh
- Run Time
- Up to 7 hours
Connections & Expansion
- Slots
- 1 x microSD
- Micro-HDMI , Micro-USB 2.0 , Headphone output
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Word Mobile, Excel Mobile, PowerPoint Mobile
- Black
- Integrated Options
- G-sensor
- Capacitive touch screen
- Included Accessories
- Power adapter
- Cables Included
- Micro-USB to USB cable
