Built-in DSL modem
Directly connects you to the internet wirelessly -- no separate DSL modem required. The Linksys X1000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
Fast wireless speed
The Linksys X1000 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates of up to 300 Mbps.
Reliable wireless coverage
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home*.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Cisco Connect Express
Control your network with ease from your android or iOS mobile device with the Cisco Connect Express app, including adding devices and giving guests access.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customise settings or quickly add new devices to your network. Cisco Connect enables you to:
Create a separate, password protected network for guests
Limit access time and access to certain websites with parental controls
Access advanced network settings easily
Measure your connection speed with the Broadband Speed Meter
Perform regular automated update checks for firmware and software with the option to install
Built-in DSL modem
Directly connects you to the Internet wirelessly - no separate DSL modem required. The Linksys X1000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem. -
Fast wireless speed
The Linksys X1000 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates of up to 300 Mbps. -
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home. -
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected. -
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer. -
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network.
- Linksys X1000 - wireless router - DSL modem - Wi-Fi - desktop, wall-mountable
- Wireless router - DSL modem - 3-port switch (integrated)
- Enclosure Type
- Desktop, wall-mountable
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- TR-069
- IPv6 support, MIMO technology, wall mountable, Wi-Fi Protected Setup (WPS), reset button
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 18 cm x 16.7 cm x 3.43 cm
- 285 g
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 3-port switch (integrated)
- Enclosure Type
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Static IP routing
- TR-069
- Encryption Algorithm
- WPA, WPA2
- Status Indicators
- Power, WAN, LAN, wireless
Communications
- DSL modem
- WAN: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Power Device
- External power adapter
- Cables Included
- 1 x phone cable , 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 18 cm
- 16.7 cm
- 3.43 cm
- 285 g
- Limited warranty - 2 years
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
