Linksys WUSB6300 Dual Band Wireless AC1200 Adapter
Quicklinx: 9HMWWS00 Mfr#: WUSB6300-EJ
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11a, IEEE 802.11b, IEEE 802.11n + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
12 In Stock
£20.92 ex VAT
£25.10 inc VAT
Next Generation Wireless Technology
Connect and upgrade your laptop or desktop computers to the newest, most powerful wireless-AC technology.
Ultimate Wireless Speed and the Power of Dual-Band
Up to 867 Mbps speed on Wireless-AC 5 GHz band or up to 300 Mbps speed on Wireless-N 2.4 GHz band
HD Video and Gaming Ready
Stream HD video and online gaming simultaneously throughout your home.
Peformance Investment Protection
Compatibility with Wireless-A (802.11a), Wireless-B (802.11b), Wireless-G (802.11g), Wireless-N (802.11n) and Wireless-AC (802.11ac) Wi-Fi Standards.
Wi-Fi Security
Supports up to 128-bit encryption (WEP, WPA and WPA2).
Easy Setup with Router or Access Point
Support WPS (Wi-Fi Protected Setup) button for easy connection with wireless router or wireless access point.
Easy Computer Setup and Compatibility
Easy to use CD setup wizard and compatible with Microsoft Windows 8, 7, Vista SP1/SP2 and XP SP3.
Take Advantage of New Wireless-AC Routers, Access Points and Extenders
Compatible with all Wireless-AC 802.11ac routers, access points and extenders (Linksys, Belkin and others).
  • USB plug
    Connect this end to any available USB port on your computer.
  • Power/status LED
    Flashes when there is wireless network activity.
  • WPS/security LED
    Indicates security status and provides feedback during Wi-Fi Protected Setup handshaking.
  • Wi-Fi Protected Setup (WPS) button
    Press this button and the WPS button on your router or access point to connect your computer to the wireless network.
Linksys WUSB6300 - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
8.9 cm x 3 cm x 1.1 cm
17 g
Wi-Fi 5
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Network adapter
External
SuperSpeed USB 3.0
Wireless
Data Transfer Rate
867 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, status, link/activity, WPS
128-bit encryption, WPS
Aerial
Antenna
Internal
Antenna Qty
2
Encryption Algorithm
WPA, WPA2, WEP
C-Tick, IC, RoHS, WEEE, iDA
Software Included
Drivers & Utilities
8.9 cm
3 cm
1.1 cm
17 g
10 - 85% (non-condensing)
Protocol: IEEE 802.11a
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: Linksys
