Linksys WRT1900AC Smart Wi-Fi Router
Quicklinx: 9FCRWS00 Mfr#: WRT1900AC
  • IEEE 802.11n
Performance Perfected with the WRT1900AC
Engineered to deliver best-in-class networking performance, the Linksys WRT1900AC Dual Band Gigabit Wi-Fi Router delivers an unmatched user experience and ultimate Wi-Fi coverage for your home. We've upgraded the iconic Linksys blue-and-black design and outfitted the router with the latest Wireless-AC platform along with the industry's first four antenna configuration with a powerful 1.2 GHz dual-core ARM to provide exceptional signal strength and range to simultaneously support multiple users. We also added a unique dual eSATA/USB 2.0 and a USB 3.0 port to the Linksys WRT1900AC to conveniently connect an array of devices and experience lightning-fast transfer speeds.
The WRT1900AC features exclusive SMART Wi-Fi software to monitor and control your network anywhere and anytime. It's our first router to offer the Network Map smart tool, providing an intuitive at-a-glance view of your entire network.
Eliminate dead zones - even in large multistory homes - with four adjustable external antennas.
Most advanced wired connections
For blazing-fast performance, we equipped the WRT1900AC with four Gigabit Ethernet ports-which are 10 times faster than Fast Ethernet to provide the fastest wired speeds. Using the USB 3.0 port, you can add external storage or other devices to share content across your network. For those with an external SATA storage device, the WRT1900AC is outfitted with a unique eSATA port for added convenience and optimal data transfer rates; it can also serve as a USB 2.0 port.
App WiFi control
Monitor and Control Your Network--Anywhere, Anytime With the industry-leading SMART Wi-Fi software you can monitor and control a home network from anywhere, anytime using a PC or mobile device. You can set parental controls to restrict Internet access during certain times of the day and create secure Wi-Fi passwords for your guests. You can also monitor activity on your home network, add new devices, and check upload and download speeds.
Linksys WRT1900AC - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), IPSec passthrough
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
24.6 cm x 5.2 cm x 19.4 cm
2 kg
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac, IC, FCC
ARM 1.2 GHz
RAM
256 MB DDR3 SDRAM
Flash Memory
128 MB
Status Indicators
Port status, power
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , Storage: 1 x USB 2.0 / eSATA-300
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
1 x network cable
Software Included
Smart Wi-Fi
24.6 cm
5.2 cm
19.4 cm
2 kg
Limited warranty - 1 year
