Best for:
Standard-sized homes, flats, and halls of residence, surfing the Web, emailing and printing wirelessly, and connecting multiple devices
Features:
Wireless-N (2.4 GHz)
Fast Ethernet 4-port switch
High speed up to 300 Mbps
Fast wireless speed
The Linksys E1200 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates of up to 300 Mbps.
Reliable wireless coverage
MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network. Cisco Connect enables you to:
Create a separate, password protected network for guests
Limit access time and access to certain websites with parental controls
Access advanced network settings easily
Measure your connection speed with the Broadband Speed Meter
Perform regular automated update checks for firmware and software with the option to install
Fast wireless speed
The Linksys E1200 offers fast speed to connect your computers, wireless printers and other Wi-Fi devices at transfer rates up to 300 Mbps speed. -
Built with leading 802.11n wireless technology, the Linksys E1200 offers reliable range to create a powerful wireless network. MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home. -
Advanced security
Keep Wi-Fi freeloaders and Internet threats at bay with WPA/WPA2 encryption and SPI firewall to help keep your network protected.
- Linksys E1200 - wireless router - 802.11b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Routing Protocol
- RIP, static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- Firewall protection, DMZ port, MAC address filtering, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 18.9 cm x 15.2 cm x 3.1 cm
- 253 g
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, UL, cUL, ICES-003, RSS-210, FCC
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 18.9 cm
- 15.2 cm
- 3.1 cm
- 253 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.85 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.22 |
