The Linksys WAP300N is a 4-in-1 device which functions as an access point, access point client, bridge or as a range extender. With Wireless-N technology and selectable dual band of 2.4 GHz and 5 GHz you will be able to gain more speed and range while minimizing any interference. Equipped with the detachable antennas, built in DHCP server and IPv6 support, you will be guaranteed the latest in technology
Wireless Convenience
Now you can grow your network by adding computers, printers and other wireless devices, without stringing cables. Reliable connectivity allows you to move your laptops, or set up your devices all around your home or office.
Easy Configuration
Push-button setup helps make it simple to add devices to your new wireless network. With Wi-Fi Protected Setup™, you just push a button on the Access Point and on your other device to automatically create the wireless connection. Device and security configuration is a snap with the browser-based configuration utility.
Secure Wireless
Advanced security features such as WPA2, WEP and Wireless MAC Filtering.
4-in-1 Device
Customize your wireless network expansion with 3 additional modes:
Bridge: Wirelessly join multiple networks together**
Media Connector: Connect wired devices to a wireless network
Range Extender: Increase existing wireless coverage
High Speed Connection
Connect at speeds up to 300Mbps for Fast transfer rates*.
Features:*
Create a new wireless network in hard to reach areas
Upgrade your network to Wireless-N
4-1 product to customize your wireless expansion
Experience faster video streaming and sharing
Wireless convenience
Now you can grow your network by adding computers, printers and other wireless devices, without stringing cables. Reliable connectivity allows you to move your laptops, or set up your devices all around your home or office. -
Easy configuration
Push-button setup helps make it simple to add devices to your wireless network. With Wi-Fi Protected Setup, you just push a button on the access point and on your other device to automatically create the wireless connection. Device and security configuration is a snap with the browser-based configuration utility.
- Linksys Wireless Access Point N300 Dual Band WAP300N - radio access point
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- Microsoft Windows 7, Microsoft Windows XP SP3 or later, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.8 or later
- 18.87 cm x 15.17 cm x 3.12 cm
- 207 g
- 2-year warranty
- 18.87 cm
- 15.17 cm
- 3.12 cm
- 207 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Port status, power, WPS
- MAC address filtering, IPv6 support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), wireless bridge mode, reset button, Wireless Client Mode
- Encryption Algorithm
- WPA, WPA2, WEP
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45 , 2 x aerial
- Cables Included
- 1 x network cable
- UL, cUL, ICES-003, RSS-210, FCC
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.18 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.05 |
