Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
Seamless connectivity
Experience uninterrupted Internet with the Linksys VELOP Whole Home Mesh Wi-Fi System, featuring dual-band technology and seamless roaming for consistent coverage throughout your home. -
Enhanced performance
Equipped with MU-MIMO and beamforming technology, this Wi-Fi system ensures high-speed connectivity for multiple devices, optimizing your online experience. -
Comprehensive coverage
The system includes two routers, designed to provide extensive Wi-Fi coverage, eliminating dead zones and buffering in every corner of your space. -
Advanced security
Keep your network safe with WPA2 encryption, safeguarding your personal information and protecting your devices from unauthorized access.
- Linksys VELOP Whole Home Mesh Wi-Fi System WHW0102 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
- Wi-Fi system - mesh
- Enclosure Type
- Desktop
- Wi-Fi System Components
- 2 routers
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Frequency Band
- 2.4 GHz / 5 GHz
- Auto-sensing per device, reset button, MU-MIMO technology, beamforming technology, dual band, seamless roaming
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- White
- 7.87 cm x 7.87 cm x 14 cm
- 322 g
- System Requirements
- Android 4.0.3 or later, Apple iOS 8.0 or higher
- Localisation
- United Kingdom
- Wi-Fi system - mesh - 2-port switch (integrated)
- 2 routers
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Encryption Algorithm
- WPA2
- Wi-Fi Rating
- AC1300
- Mesh Networking
- Processor
- 716 MHz
- RAM
- 256 MB
- Flash Memory
- 256 MB
Line Properties
- Line Coding Format
- 256 QAM
- WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Power Device
- External power adapter
- Installed Qty
- 2
- Enclosure Colour
- White
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 7.87 cm
- 7.87 cm
- 14 cm
- 322 g
