Linksys VELOP Whole Home Mesh Wi-Fi System WHW0101
Quicklinx: FD8FWS00 Mfr#: WHW0101-UK
  • IEEE 802.11n
£63.46 ex VAT
£76.15 inc VAT
Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
  • Tri-band technology
    Three bands that deliver fast combined Wi-Fi speeds to more devices.
  • Modular Wi-Fi solution
    The modular design performs well within every home type, situation, and footprint. Each node is a powerful tri-band connection point offering a large area of coverage.
  • Sleek, compact design
    Designed for high-performance Wi-Fi. Each device features a beautiful, sleek design that can be placed in open spaces, and away from obstructions to provide the best in-home Wi-Fi experience.
Linksys VELOP Whole Home Mesh Wi-Fi System WHW0101 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
Router
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Frequency Band
2.4 GHz / 5 GHz
Auto-sensing per device, reset button, MU-MIMO technology, beamforming technology, dual band, seamless roaming
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
White
7.87 cm x 7.87 cm x 14 cm
322 g
Android 4.0.3 or later, Apple iOS 8.0 or higher
United Kingdom
Wi-Fi system - mesh - 2-port switch (integrated)
Router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2
Wi-Fi Rating
AC1300
Mesh Networking
716 MHz
RAM
256 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
Installed Qty
1
Enclosure Colour
White
1 x network cable
United Kingdom
7.87 cm
7.87 cm
14 cm
322 g
Type: Wi-Fi system
Connectivity: Wired
Connectivity: Wireless
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: Bluetooth 4.1
Brand: Linksys
