Mount your Velop nodes on nearly any wall with this sleek, space-saving wall mount. Install Velop nodes across your home or business - in hallways, kitchens, lobbies, conference rooms, and more.
Position Velop anywhere for whole-home Wi-Fi
Mount your Velop nodes on nearly any wall with this sleek, space-saving wall mount. Install Velop nodes across your home or business - in hallways, kitchens, lobbies, conference rooms, and more. -
Optimize your mesh Wi-Fi system
Your Velop node with Intelligent Mesh Technology already helps you place your node. The wall mount makes it even easier to install your Velop mesh Wi-Fi system for optimal coverage. -
Coil your cables for a clean look
Built-in cable management allows you to neatly coil excess cable within the mount for a sleek, tidy look. -
Fits Velop tri-band and dual-band nodes
The included inserts let you adjust the wall mount to fit a range of different Velop models. The Linksys Velop Wall Mount is not compatible with Linksys Velop Wi-Fi 6 series. -
Easy to install
The Velop Wall Mount comes with all the screws and anchors needed for an easy, secure installation. Place the mount near an A/C outlet to supply power to your Velop node.
- Linksys Velop network device mounting bracket
- Product Type
- Network device mounting bracket
- Placing / Mounting
- Surface mountable, wall mountable
- 7.8 cm x 9.3 cm x 11.1 cm
- 108 g
- 2-year warranty
- Product Type
- 7.8 cm
- 9.3 cm
- 11.1 cm
- 108 g
- Mounting Kit
- Included
- Limited warranty - 2 years
