Linksys VELOP Dual Band AC2400 2PK
Quicklinx: FD8BWS00 Mfr#: VLP0102-UK
  • IEEE 802.11n
£119.11 ex VAT
£142.93 inc VAT
Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
Linksys VELOP Whole Home Mesh Wi-Fi System VLP0102 - Wi-Fi system - Wi-Fi 5, Bluetooth - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
2 routers
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Frequency Band
2.4 GHz / 5 GHz
Intelligent Assistant
Alexa
Auto-sensing per device, reset button, MU-MIMO technology, beamforming technology, seamless roaming
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
7.9 cm x 7.9 cm x 14 cm
Android 4.0.3 or later, Apple iOS 8.0 or higher
United Kingdom
Wi-Fi system - mesh - 2-port switch (integrated)
2 routers
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2
Wi-Fi Rating
AC1200
Mesh Networking
716 MHz
RAM
512 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM
Internet of Things (IoT)
Alexa
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
External power adapter
Installed Qty
2
1 x network cable
United Kingdom
7.9 cm
7.9 cm
14 cm
Type: Wi-Fi system
Connectivity: Wireless
Connectivity: Wired
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Bluetooth 4.1
Brand: Linksys
