Linksys VELOP Dual Band AC1200 1PK
Quicklinx: FD89WS00 Mfr#: VLP0101-UK
  • IEEE 802.11n
£73.30 ex VAT
£87.96 inc VAT
Velop Dual-Band Series is a family Whole Home Wi-Fi system of modular nodes that work seamlessly together to create one high-speed, high-range Mesh network for your entire home. Unlike traditional routers with range extenders, it only uses one Wi-Fi network name and password to give you seamless and secure Wi-Fi everywhere. Velop's Intelligent Mesh Wi-Fi functionality, easy set-up and beautiful design make it the perfect upgrade from a traditional router system.
Linksys VELOP Whole Home Mesh Wi-Fi System VLP0101 - wireless router - Wi-Fi 5, Bluetooth - desktop
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Frequency Band
2.4 GHz / 5 GHz
Intelligent Assistant
Alexa
Auto-sensing per device, parental control, firmware upgradable, reset button, MU-MIMO technology, Spot Finder Technology, beamforming technology, Backhaul Technology, guest access, seamless roaming, bridge mode
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
White
7.9 cm x 7.9 cm x 14 cm
Android 4.0.3 or later, Apple iOS 8.0 or higher
United Kingdom
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA2
Wi-Fi Rating
AC1300
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, FCC Class B certified
716 MHz
RAM
256 MB
Flash Memory
256 MB
Status Indicators
Status
Line Properties
Line Coding Format
256 QAM
Internet of Things (IoT)
Alexa
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
Installed Qty
1
Enclosure Colour
White
1 x network cable
United Kingdom
7.9 cm
7.9 cm
14 cm
Limited warranty - 3 years
Type: Wireless router
Connectivity: Wireless
Connectivity: Wired
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: Bluetooth 4.1
Brand: Linksys
