Linksys USB 3.0 Gigabit Ethernet Adapter
Quicklinx: C0HMWS00 Mfr#: USB3GIG-EJ
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet
Compatibility: Mac, PC
Type: Network adapter
£15.45 ex VAT
£18.54 inc VAT
Since many laptops and Ultrabooks are not equipped with a Gigabit Ethernet port, the USB3GIG is a valuable add-on, delivering high-speed data transfers via USB 3.0. Featuring a Gigabit Ethernet port on one end and a USB 3.0 connector, now you can quickly download large files, stream movies, and get work done. Plug the USB3GIG's USB 3.0 connector into your laptop and connect Gigabit Ethernet port to an Ethernet cable and router. The adapter's flexible cord makes it easy to connect, even in tight spaces. By adding an Ethernet port to your ultra-slim laptop, notebook, or tablet, the USB Ethernet adapter Gigabit USB 3.0 provides an alternative to connecting to the Internet via Wi-Fi, which can be spotty and unreliable depending on your location. The adapter is the perfect solution for the business traveler who prefers a secure and fast wired Ethernet connection. Ideal for travel, the USB3GIG features a slim, flexible design that fits easily in a pocket or laptop case. A travel cap keeps it protected when not in use.
  • Ultra-fast wired speeds
  • Quick, easy setup
  • Enjoy a reliable connection in hotels, airports, and more
  • Compact, flexible design
Linksys USB Ethernet Adapter USB3GIG - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.535 cm x 1.765 cm
Length
20.23 cm
23 g
Europe
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
Network adapter
External
SuperSpeed USB 3.0
Europe
Ports
Gigabit Ethernet
Wired
Cabling Type
Status Indicators
Link/activity
1 x 1000Base-T - RJ-45
FCC Class B certified
2.535 cm
1.765 cm
Length
20.23 cm
23 g
70 °C
10 - 90% (non-condensing)
C0HM C2G 2m USB 2.0 A/B Cable - Black In Stock £3.61
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: Mac
Compatibility: PC
Brand: Linksys
