Simple, universal, plug-and-play 10 Gigabit SFP+ transceiver supporting managed switches will allow customers to build a fast, reliable backbone for data centers, enterprise and service provider transport applications. Extend the connection distance significantly with this transceiver.
Universal plug-and-play compatibility
Simple, universal, plug-and-play 10 Gigabit SFP+ transceiver supporting compatible managed switches will allow customers to build a fast, reliable backbone for data centers, enterprise and service provider transport applications. -
Fiber network expansion port
Extend the connection distance beyond the 100 m limit of the RJ-45 port - up to 300 m for this multi-mode module.
- Linksys Business LACXGSR - SFP+ transceiver module - 10 GigE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10 GigE
- Max Transfer Distance
- 300 m
- Designed For
- Business LGS552, LGS552P, Smart LGS318P, Smart LGS326P
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10 GigE
- 10 Gbps
- 850 nm
- 300 m
- 1 x Ethernet 10GBase-SR - LC multi-mode x 2
- 0 °C
- 70 °C
- Designed For
- Linksys Business LGS552, LGS552P, Smart LGS318P, Smart LGS326P
Linksys SMB LACXGSR SFP+ Transceiver Module 10 Gigabit Ethernet
