The Belkin Secure Flip 2-port UltraHigh Def KVM switch enables users to securely switch between two DisplayPort computers while presenting information from each source at a time. The Secure Flip offers superior security and data protection by providing true data path isolation between systems and networks. The Flip KVM switch securely toggles control of video, keyboard, mouse and audio between the two sources allowing navigation by selecting the switch push buttons or controlling it remotely via remote control device. The Flip UltraHigh Def KVM is designed, manufactured and certified to the latest NIAP Protection Profile Ver.3.0 standard. The latest NIAP Protection Profile ensures agencies are receiving the appropriate security for keyboard and pointing devices, superior protection for HDMI displays and improved audio device security.
Dedicated processors with emulators for every port
Isolated port paths for video and audio to prevent data leaks between computers. -
Unidirectional data paths
Optical data diodes prevent peripherals from being used to breach systems. -
Display security
Protected display interface prevents data leakage via the monitor. -
Peripheral management
USB device detection prevents unauthorized peripheral usage. -
Anti-tampering
Internal electrical sensors render unit inoperable if opened. -
Secure labeling
Holographic tamper-evident product label provides visual indication and prevention of tampering. -
Fast switching
No keyboard or mouse delays when switching ports. -
High retention connectors
Semi-locking USB ports prevent accidental disconnection. -
Secure packaging
Tamper-evident packaging ensures product is not tampered with during transport.
- Belkin Secure Flip KVM Switch - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 10.92 cm x 7.62 cm x 2.54 cm
- 730 g
- Localisation
- United Kingdom
- 3-year warranty
- Designed For
- P/N: F1DN104P-3EA, F1DN104Q-3EA, F1DN104W-3EA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 30 Hz
- Status Indicators
- Status
- 2 x DisplayPort input , 2 x keyboard (USB) / mouse (USB) Type A , 2 x audio input mini-jack , 1 x HDMI output , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x audio output mini-jack , 1 x remote control
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Included Accessories
- Remote control
- Cables Included
- 1 x keyboard / mouse / video / audio cable - 1.8 m , 1 x keyboard / mouse / video / audio cable - 60 cm
- Plug and Play, FCC, DDC, ICES, EDID compatible
- Localisation
- United Kingdom
- 10.92 cm
- 7.62 cm
- 2.54 cm
- 730 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
