Linksys Secure Flip 2-port KM switch - UK Version
Quicklinx: FD7MWS00 Mfr#: F1DN102K-3uk
The Belkin Secure Flip 2-port KM switch enables users to securely switch between two sources while information from all sources can be viewed simultaneously on different displays. Each source can be connected to up to four displays. The Flip KM switch securely toggles control of keyboard, mouse and audio between the two sources allowing intuitive navigation by seamless cursor switching (SCS). Once mouse cursor crosses display borders, mouse, audio and keyboard become active on the system connected to that display. The Belkin Secure Flip KM is designed, manufactured and certified to the latest NIAP Protection Profile Ver. 3.0 standard. The latest NIAP Protection Profile ensures agencies are receiving the appropriate security for Keyboard and Pointing Devices and improved audio device security.
  • Dedicated processors with emulators for every port
    Isolated port paths for video and audio to prevent data leaks between computers.
  • Unidirectional data paths
    Optical data diodes prevent peripherals from being used to breach systems.
  • Peripheral management
    USB device detection prevents unauthorized peripheral usage.
  • Anti-tampering
    Internal electrical sensors render unit inoperable if opened.
  • Secure labeling
    Holographic tamper-evident product label provides visual indication and prevention of tampering.
  • Fast switching
    No keyboard or mouse delays when switching ports.
  • High retention connectors
    Semi-locking USB ports prevent accidental disconnection.
  • Secure packaging
    Tamper-evident packaging ensures product is not tampered with during transport.
Belkin Secure Flip KM Switch - keyboard/mouse/audio switch - 2 ports
Keyboard/mouse/audio switch - 2 ports
Subtype
KM
Ports
2 x keyboard/mouse/audio
KVM Users Qty
1 local user
AC 120/230 V
10.92 cm x 7.62 cm x 2.54 cm
540 g
United Kingdom
3-year warranty
Enclosure Type
Desktop
Subtype
KM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB, PS/2
Status Indicators
Status
1 x keyboard (PS/2) , 2 x keyboard (USB) / mouse (USB) Type A , 2 x audio input mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x audio output mini-jack , 1 x remote control
External power adapter
AC 120/230 V
1 x keyboard / mouse / video / audio cable - 1.8 m , 1 x keyboard / mouse / video / audio cable - 60 cm
FCC, ICES, Plug and Play, EDID compatible, DDC
United Kingdom
10.92 cm
7.62 cm
2.54 cm
540 g
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
