Your basket is empty
Linksys RE7000 Wi-Fi Range Extender 802.11a/b/g/n/ac Dual Band
Quicklinx: C7C7WS00 Mfr#: RE7000-UK
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 1.9Gbps
Protocol: IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£95.74 ex VAT
£114.88 inc VAT
Extend your home Wi-Fi to hard-to-reach locations in your home such as your backyard, garage, or bedroom so you can get the Wi-Fi to smartphones, tablets, and laptops to enjoy streaming HD movies, online gaming, social media, and more. No more dropped connections for voice calls from smartphones, or tablets when you move from one room to another or to your backyard when synced with a Linksys MAX-STREAM router or other supported routers. This range extender is compatible with any Wi-Fi router, including those from Internet service providers. There's no need to adjust your router's settings when installing the extender.
Linksys RE7000 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
12.6 cm x 8.1 cm x 4.6 cm
255 g
12.6 cm
8.1 cm
4.6 cm
255 g
United Kingdom
External
Wireless
Data Transfer Rate
1.9 Gbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), MU-MIMO technology, Cross-Band Technology, Spot Finder Technology, beamforming technology
1 x 1000Base-T - RJ-45
C7C7 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.13
C7C7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.14
C7C7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.62
C7C7 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.89
C7C7 C2G TruLink Media Gateway RJ45 Cap In Stock £0.54
C7C7 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £43.15
Speed: 1.9Gbps
Compatibility: PC
Brand: Linksys
Price Range Ex VAT: 50 - 100
