Built-in DSL Modem - Directly connects you to the internet wirelessly -- no separate DSL modem required. The Linksys X3500 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
The Linksys X3500 offers fast speed to connect your computers, Internet-ready TVs, game consoles and other WiFi devices at transfer rates up to 300 + 450 Mbps for an optimal home network experience.
Reliable Wireless Coverage - The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced Security - Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
The Power of Dual-Band - Double your network bandwidth with Dual-Band N (2.4 and 5 GHz) designed to avoid interference and maximise throughput. Ideal for HD video streaming, high speed file transfers and wireless gaming.
Beneflfits of Gigabit - Use the four Gigabit Ethernet ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices like computers, hard drives, and servers.
Built-in USB port and DLNA CertifiedĀ® media server - The USB port let you add storage devices and printers to your network to share files or print wirelessly throughout your home. The built-in DLNA CertiflfiedĀ® media server enables media streaming to your TV, Xbox 360, PS3, or other DLNA compatible devices.
Built-in DSL modem
Directly connects you to the Internet wirelessly - no separate DSL modem required. The Linksys X3500 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem. -
Superior wireless speed
The Linksys X3500 offers fast speed to connect your computers, Internet-ready TVs, game consoles and other Wi-Fi devices at transfer rates up to 300 + 450 Mbps for an optimal home network experience. -
Reliable wireless coverage
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home. -
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected. -
The power of dual-band
Double your network bandwidth with Dual-Band N (2.4 and 5 GHz) designed to avoid interference and maximize throughput. It is ideal for HD video streaming, high speed file transfers and wireless gaming. -
Benefits of Gigabit
Use the four Gigabit Ethernet ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices like computers, hard drives, and servers. -
Built-in USB ports and DLNA Certified media server
The USB ports let you add storage devices and printers to your network to share files or print wirelessly throughout your home. The built- in DLNA Certified media server enables media streaming to your TV, Xbox 360, PS3, or other DLNA compatible devices.
- Header / Packaged Quantity
- 1
- Miscellaneous / Encryption Algorithm
- 104-bit WEP, 128-bit WEP, 40-bit WEP, 64-bit WEP, WPA, WPA-Enterprise, WPA2, WPA2-Enterprise
- Networking / WAN Ports Qty
- 2
- Service & Support / Type
- 2 years warranty
- Dimensions & Weight / Depth
- 20 cm
- Dimensions & Weight / Width
- 21.5 cm
- Dimensions & Weight / Height
- 4 cm
- Dimensions & Weight / Weight
- 451 g
- Networking / Integrated Switch
- 4-port switch
- Networking / Wireless Protocol
- 802.11 a/b/g/n
- Modem / Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- Networking / Form Factor (FE)
- Desktop, Wall-mountable
- Networking / Network / Transport Protocol
- DHCP, L2TP, PPPoE, PPTP
- Standards
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Modem / Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
- Header / Manufacturer
- Linksys
- Header / Product Line
- Linksys
- Header / Model
- N750 Dual-Band Wireless Router with ADSL2+ Modem and USB (X3500)
- Header / Compatibility
- PC
- Networking / Routing Protocol
- Static IP routing
- Header / Country Kits
- United Kingdom
- Networking / Connectivity Technology
- Wired, Wireless
- Wireless router
